[Solved] PopupMenu and PMIA_CommKey ?
Post by zzd10h »
I'm trying to add a shortcut key to a PopupMenu with PMIA_CommKey.
The shortcut is well displayed but have no effect.
Is something special to add to handle a shortcut ?
Thank you by advance for your help.
Re: PopupMenu and PMIA_CommKey ?
Are you using the hook or PM_HANDLEINPUT ?
I think from scanning the autodocs you need the latter for keyboard short cuts. Never having used it I can't help more.
Post by zzd10h »
Thank you for your help.
I use the the handler like in the PopupMenu SDK example.
Like I don't know how to use PM_HANDLEINPUT, I simply use WMHI_RAWKEY in my window event loop to trap IEQUALIFIER_RCOMMAND and the key code and it works :)
I wondered if it was possible to do it easy like in NewMenu and MenuClass shortcuts.
Re: [Solved] PopupMenu and PMIA_CommKey ?
AFAIK the shortcuts displayed on context menus are for information only. They are never trapped, you need to do it yourself (or add a corresponding item to the main menu strip). Intuition context menus work the same way (except the display of the shortcut doesn't work).
Post by zzd10h »
@Chris
Thank you, as I wrote in the previous post, I did it myself.
