initrd to boot Linux from USB flash drives
Stanglnator posted in the os4welt forum, that it is possible to boot a Linux distribution from a USB flash drive independent of the Linux device names like sdf1, sdg1 etc.
The problem is, that Linux doesn't always give the partitions on the USB flash drives the same device names. Sometimes the partition's name is sdf1 or sdg1 etc. Thereby it isn't possible to set up a CFE entry for a Linux distribution on a USB stick because of the changing partition names.
The solution is to use UUID (universally unique identifier). It can be used to identify a file system (partition) in a clearly independent form.
With cat /etc/fstab and ls -l /dev/disk/by-uuid you can figure out the UUID of the Linux partition.
You need an initial ramdisk (initrd) to boot a Linux system from a partition identify by UUID.
I created an initrd for the longterm kernel 4.1.12 yesterday.
Download: initrd.img-4.1.12
I will add an initrd to every new kernel. :-)
With the following commands you can boot the Linux system from a partition identify by UUID:
  1. Code: Select all
    CFE> ramdisk -z -addr=0x24000000 -fatfs cf0:initrd.img-4.1.12
  2. Code: Select all
    CFE> setenv bootargs "root=UUID=<a-very-large-number>"
    For example:
    CFE> setenv bootargs "root=UUID=2d781b26-0285-421a-b9d0-d4a0d3b55680"
  3. Code: Select all
    CFE> boot -elf -noints -fatfs cf0:vmlinux-4.1
Thanks to Stanglnator for this really interesting solution!
zappa2009
Re: initrd to boot Linux from USB flash drives
Post by zappa2009 »
Nice.
An other Method is
sudo blkid
It lists all Devices with an UUID and PARTUUID and FS-Type that will be found.
e@e:~$ sudo blkid
/dev/sda1: UUID="9CEEA6B7EEA6895A" TYPE="ntfs" PARTUUID="000436df-01"
/dev/sda2: UUID="95a0507f-bcbe-4eaf-901f-5a687e97d5e6" TYPE="ext4" PARTUUID="000436df-02"
/dev/sda3: UUID="91ff2d24-d277-4ef0-b3e1-717f322386bc" TYPE="swap" PARTUUID="000436df-03"
/dev/sdb1: UUID="d5dffc46-e96f-43cf-8957-13d95873c49f" TYPE="ext4" PARTUUID="000d379a-01"
zappa2009
Post by zappa2009 »
Hi again.
with the initrd.img-4.1.12 you can use LABEL instead of UUID as bootargs for the Kernel.
setenv bootargs "root=LABEL=fedora17"
In my case is this the LABEL of my fedora17 installation on a USB stick.
And I rename the /etc/fstab on the Linux from UUID to LABEL. On my Stick i do this
LABEL=fedora17 /  ext4 defaults 1 1
You can set this with Gparted , just make sure the partition is umount. Can be done with a RMB on the Partition and select umount.
zappa2009 wrote:Hi again.
Fantastic! Thank you for the hint! :-)
