Wb Titlebar transparency
kicko
Post by kicko »
Hi.
I cant find anywhere in the GUI nor workbench prefs to change transparency for wb title bar.
Also when using "automatic" for hiding the titlebar (wb prefs) when i move the mouse on top it shows the titlebar behind my windows. Can i somehow change this so the workbench title bar is show ontop (over the windows).
Also when trying to decrease the "window title bar gadget size" nothing happens. I want to make the title bar thinner/smaller.
If workbench lacks this functions maybe add it as feature request ?
Thanks for help.
ZeroG
Re: Wb Titlebar transparency
Post by ZeroG »
This will only work if the OS-Skin you are using does not set a Bitmap for the title bar.
