Hello.
Is there a place where we can see all the "replacement methods" for the "deprecated functions" from SDK 53.20 to 53.30 ?
Thank you.
Replacements for Deprecated functions.
Re: Replacements for Deprecated functions.
If you look up the autodoc for the library with the deprecated function, it should tell you the recommended replacement. Most deprecated functions in DOS are just renamed.
No there is not but we are working on improving the AmigaOS Documentation Wiki where this kind of information should go IMHO.AmiDARK wrote:Is there a place where we can see all the "replacement methods" for the "deprecated functions" from SDK 53.20 to 53.30 ?
If you could be more specific on which functions you are concerned about we can focus on those areas first. Otherwise it is just too big a job.
i've taken a first pass at this. please see http://wiki.amigaos.net/wiki/Deprecated_Functions and let me know if it's what you're needing.ssolie wrote:No there is not but we are working on improving the AmigaOS Documentation Wiki where this kind of information should go IMHO.AmiDARK wrote:Is there a place where we can see all the "replacement methods" for the "deprecated functions" from SDK 53.20 to 53.30 ?
-- eliyahu
I think the preferred replacements for some of the deprecated "libamiga.a" functions are actually tags like ASOT_IOREQUEST, ASOT_MESSAGE & ASOT_PORT used with AllocSysObject() in exec.library.eliyahu wrote:i've taken a first pass at this. please see http://wiki.amigaos.net/wiki/Deprecated_Functions and let me know if it's what you're needing.
You might also want to mention in "DOS library" that most DOS structures should now be Allocated with AllocDosObject.
- colinw
As far as DOS goes, there's a bunch more deprecated functions than are mentioned in the article.eliyahu wrote: i've taken a first pass at this. please see http://wiki.amigaos.net/wiki/Deprecated_Functions and let me know
-- eliyahu
If you load the include_h/interfaces/dos.h file into notepad and search for "DEPRECATED",
you will find many more...
Most deprecated ones are due to 32 bit filesize parameter limitations, some old functions are simply broken,
and some functions may just be renamed for consistency.
It might be nice to make a minor mention in the article, the reason why a change has been made.
The autodoc will generally provide far more detail.
