Hello.
With the previous SDK 53.20 I was able to compile projects under AmiDevCPP.
But I installed 53.30, I now get an error concerning AS saying that paramater -mppc is unknown.
Can someone help me with this ?
Regards,
AmiDARK
(Solved) AmiDevCPP as.exe and "mppc" support.
- salass00
Re: AmiDevCPP as.exe and "mppc" support.
I don't see what this has to do with the SDK since the AmigaOS 4.x SDK doesn't include any cross-compilers...AmiDARK wrote:Hello.
Regards,
AmiDARK
Your problem seems to be with your cross-compiler binutils install rather. I assume you are invoking "as" with the correct cross prefix ("ppc-amigaos-as" rather than just plain "as")?
I'm also not sure what the -mppc option is supposed to be doing as ppc code should be the default for ppc-amigaos-as...
- Daytona675x
Finetuning for concrete CPUs.I'm also not sure what the -mppc option is supposed to be doing as ppc code should be the default for ppc-amigaos-as...
https://sourceware.org/binutils/docs/as ... dOpts.html
Anyway, no idea why an SDK update would break / influence the cross-compiler setup.
Warp3D driver code-basher and bug-smasher - btw.: driver writing is nothing mysterious
Re: (Solved) AmiDevCPP as.exe and "mppc" support.
In fact a folder in my AmiDevCPP AmigaOS4 SDK location was missing.
The AS.EXE that should be used for Amiga compilation was no more.
Reinstalling AmiDevCPP 0.98 fixed this problem fixing the issue.
