Wacom Cintiq 13 HD support under Linux
z!Erec
Post by z!Erec »
Hello dear Linux friends.
I'm an X1000 User and I'm now going to start testings under Linux.
Main focus is going to be Art packages and the support of gfx Tablets.
I got a few cool tablets to test :-)
I would love to know if the Wacom Drivers (Wacom Linux Project)
are part of the Ubuntu LTS 14.04 Distribution for X1000.
I know that since version 13 they are part of the x86 Distros.
Regards
z!Erec
Classic
A1200PPC*A4000DPPC*2X A4000TPPC*CD32-SX32Pro*Project: A4kTzE
NextGen
Efika 52xx*A1-XE G4*PEG II G4*MACmini G4 1,5GHz
AmigaOne X1000 "NEMO", Sapphire Radeon R9 280X TOXIC,
3Gb DDR5, PSU: C= 750W, 8GB Kingston Hyper X, 120 Gb OCZ Agility3 SSD, LG SATA DVDRW
Special
>ATARI Falcon MKX/CT60/CTPCI<
Re: Wacom Cintiq 13 HD support under Linux
z!Erec wrote:Hello dear Linux friends.
Regards
z!Erec
Hi z!Erec,
Unfortunately I don't have any knowledge about Wacom gfx tablets but I will try to add some kernel modules for these to the RC1 of kernel 4.3 tomorrow.
Have a nice weekend!
Hi z!Erec,
I released two Linux kernels with Wacom pen gfx tablets support.
Downloads:
Stable Linux kernel 4.1.7: vmlinux-4.1.7-AMIGA_one_X1000.tar.bz2
Test Linux kernel 4.3-rc1: vmlinux-4.3-rc1-AMIGA_one_X1000.tar.bz2
Please test both kernels.
z!Erec
Post by z!Erec »
Hello Christian.
Thank you
very very much.
I'm going to test those kernels.
Regards
Kymon
Classic
NextGen
Special
AlicePPC
Post by AlicePPC »
Recently i buy second hand wacom cintiq 13HD and i use in pc but i want to test in my X1000 with linux also..
Can you add suppor for wacom cintiq 13HD in our linux ppc with GUI configuration?
this is good because the cintiq need be calibrated for correct use
http://ragnarb.com/configuring-wacom-ci ... ntu-14-04/
https://blog.hials.no/schaathun/2013/10 ... -on-linux/
http://linuxwacom.sourceforge.net/wiki/ ... tion_Tools
Regards
José
Hi José,
I have already added Wacom pen gfx tablets support to the kernel. Please note: I don't have any knowledge about Wacom gfx tablets. That means I need your help with testing etc etc.
AlicePPC wrote:Recently i buy second hand wacom cintiq 13HD and i use in pc but i want to test in my X1000 with linux also..
Regards
José
AlicePPC
Post by AlicePPC »
Hello Christian.
I need install the Ubuntu for test the cintiq and look if the preferences panel appear in Ubuntu because in debian the Cintiq 13Hd driver work but we need the Gui preferences panel and in debian this menu not appear in the preferences panel and calibration option is very important.
Regards
Jose
AlicePPC wrote:Hello Christian.
Regards
Jose
Hi Jose,
You don't need to install Ubuntu for testing the Wacom Cintiq support. You only need to copy one of Julian's images to a USB flash drive and boot from.
Instructions and links:
  1. Download the image from the links above
  2. Decompress the downloaded image with 7-Zip
  3. Copy it with dd on Linux or with the USB image Tool on Windows to a USB flash drive.
    For example with Linux and the Ubuntu-Mate_16.04.img:
    dd if=Ubuntu-Mate_16.04.img of=disk drive ID
    In my case /dev/sdh:
    dd if=Ubuntu-Mate_16.04.img of=/dev/sdh
  4. Reinsert the USB flash drive. The system will mount all partitions on the USB flash drive
  5. Turn on the AmigaONE X1000 and press F to enter the CFE prompt. Insert the USB flash drive.
  6. Next enter the following at the CFE> prompt (pressing enter after each line):
    setenv bootargs "root=the_ROOT_partition_on_your_usb_flash_drive quiet ro splash rootdelay=5"
    In my case:
    setenv bootargs "root=/dev/sdd2 quiet ro splash rootdelay=5"
    I use the stable longterm kernel 4.1.20 on my CF card to boot ubuntu MATE 16.04 on the USB flash drive. You can use an other kernel if you like.
    boot -elf -noints -fatfs cf0:vmlinux-4.1
  7. The ubuntu MATE login screen appears. Please login.
    Username of amigaone has the password amigaone
Please try it.
