CD/DVD icon bug (icon still present in WB)
samo79
Post by samo79 »
I wonder why sometimes the icon of an automounted CD/DVD still remained in Workbench even if you have already expelled it ...
I was searching for a file in a couple of DVD i have, so first i put a disk, then i remove it and i inserted another disk ... as a result both DVD remained visible ! ..
See grab: http://s10.postimg.org/tuxif9ecp/cd_tray_bug.jpg
I had a similar problem with AmigaOS 4.1 Update 4 (if i remember correctly) and at the time i reported it, then apparently it seems fixed ... now i have the same problem again ...
Re: CD/DVD icon bug (icon still present in WB)
Usually it's because something has a lock on a file or directory on the CD, so that it can't be unmounted, it is not a bug.
samo79
Post by samo79 »
Yep, probably the reason is about somethings locked in background, however technically speaking this is a bug for sure ... if something "bad" happen when you dismount a device the system should "forced" its closure automatically by removing its icon from the desktop .. at least this is the normal behaviour of any other operating system, so i don't know why AmigaOS should manage this differently ...
Broken behaviour of other operating systems does not an AmigaOS bug make.
If something has a lock on the disk or a file / directory on it then unmounting it will not bode well for that app. This is exactly the same behaviout as you used to get to with floppies. It's certainly not a bug with the OS but may be caused by a bug in some other program not unlocking a file on exit.
broadblues wrote:Broken behaviour of other operating systems does not an AmigaOS bug make.
IIRC if you try to eject a disk with an active lock on it, the OS throws up a big scary warning "You MUST replace volume XXXX in device DF0" (or maybe that's open files, rather than locks).
In particular, bitmap.image seems to keep locks on files. I think it's related to the internal caching, but I don't think it should be keeping a lock?
