SDK 53.29 : freeze when using new WA_PointerType
Post by zzd10h »
trying to use new PointerType (from intuition/pointerclass.h) freezes my system as soon as I use the new pointers.
freeze :
SetWindowPointer(window, WA_PointerType, POINTERTYPE_ROTATE, TAG_DONE);
works when using a "old" pointertype:
SetWindowPointer(window, WA_PointerType, POINTERTYPE_HAND, TAG_DONE);
Are these new pointers exist really on FE ?
#define POINTERTYPE_PEN 35
#define POINTERTYPE_ROTATE 36
#define POINTERTYPE_RUBBER 37
#define POINTERTYPE_SELECT 38
#define POINTERTYPE_SMUDGE 39
thank you
salass00
Re: SDK 53.29 : freeze when using new WA_PointerType
Post by salass00 »
According to the intuition.library release notes some new pointer images were added for version 54.21 (30.7.2015). They don't mention which ones though.
Post by zzd10h »
Thanks for your reply.
Therefore, only for betatest system, right ?
My stock FE intuition version is 54.10.
zzd10h wrote:Thanks for your reply.
It shouldn't crash though :| If the pointer requested isn't available Intuition should substitute a different one (probably the default pointer) or just not change it.
salass00
Post by salass00 »
chris wrote: It shouldn't crash though :| If the pointer requested isn't available Intuition should substitute a different one (probably the default pointer) or just not change it.
The crashing should be fixed in the latest V54.23 beta version of intuition.library.
