USB In/Out sound
- tommysammy
USB In/Out sound
Please add some option in USB prefs, that play a sound when i tuck an USB stick in and pull out an USB stick like on other Os`s.Then I would like an option that i can choose between sound and a requester or i can use both of them.
Re: USB In/Out sound
Yep, not very necessary for me but agree that it would be a nice feature
- broadblues
Because the fact you inserted the usb stick isn't enough of a clue that you inserted a usb stick?
Or that the requester that opens on Workbench informing that a USB device has been attached isn't enough?broadblues wrote:Because the fact you inserted the usb stick isn't enough of a clue that you inserted a usb stick?
Personally, I'd rather see most existing bugs fixed before any new features are added. Try entering "USBCtrl restart" in a shell when there is a USB flash drive plugged in. Instant system freeze here.
It's more like to get a visual/audio feedback that the OS did register that you inserted the USB stick.broadblues wrote:Because the fact you inserted the usb stick isn't enough of a clue that you inserted a usb stick?
edit: Seems like xenic got inspired http://os4depot.net/?function=showfile& ... bsound.lha
