Kernel 4.3
Kernel 4.3
The merge window is open. Linus Torvalds added a lot of source code today.
Link: Linux git log
I released the alpha1 of kernel 4.3 with the new source code from the git.
Further information:
Here's What We Know So Far About The Linux 4.3 Kernel - phoronix.com
Linux 4.3 Scheduler Change "Potentially Affects Every SMP Workload In Existence" - phoronix.com
Download for the AmigaONE X1000: vmlinux-4.3-alpha1-AMIGA_one_X1000.tar.bz2
Re: Kernel 4.3
Nemo patch for the alpha1:
nemo_4.3-1.patch.zip
(12.61 KiB) Downloaded 541 times
Re: Kernel 4.3
A new Nemo patch for the alpha2:
nemo_4.3-2.patch.zip
(16.97 KiB) Downloaded 546 times
Re: Kernel 4.3
Linus Torvalds added a lot of source code again today. Therefore I compiled a new test version for our AmigaONE X1000.
Download: vmlinux-4.3-alpha2-AMIGA_one_X1000.tar.bz2
Unfortunately the size of our Nemo patch increased a bit because of the code changes in the interrupt system.
Power Management Update In Linux 4.3 Adds New Support, But Mostly Unexciting - phoronix
EXT3 Driver Might Not End Up Getting Removed From Linux 4.3 -phoronix
Re: Kernel 4.3
I released the alpha3 today.
Download: vmlinux-4.3-alpha3-AMIGA_one_X1000.tar.bz2
Further information: F2FS File-System Updates For Linux 4.3 - phoronix
Re: Kernel 4.3
New Nemo patch for the alpha4: nemo_4.3-3.patch
Re: Kernel 4.3
Here is the alpha4. :-)
Download: vmlinux-4.3-alpha4-AMIGA_one_X1000.tar.bz2
New: All PowerPC updates for the kernel 4.3 (Merge tag 'powerpc-4.3-1')
PLEASE PLEASE test the alpha4. I'd like to know if it works for you.
Re: Kernel 4.3
Post by zzd10h »
"PLEASE PLEASE test the alpha4. I'd like to know if it works for you."
DONE DONE, and it works fine ! :D
Re: Kernel 4.3
zzd10h wrote: DONE DONE, and it works fine ! :D
Many many thanks! :-D
Could you please test the alpha5 too? The kernel developers added the DRM fbdev emulation as default. I don't know if it works with every Radeon HD graphics card.
Download: vmlinux-4.3-alpha5-AMIGA_one_X1000.tar.bz2
Thank you in advance. :-)
New Nemo patch for the alpha5: nemo_4.3-4.patch
Re: Kernel 4.3
Post by zzd10h »
Works too with my Radeon HD R7-250X
