Black screen after msi Radeon R9 270x installed
electric-magic
Post by electric-magic »
Hello everyone,
Decided to go for warp 3D from amistore. Downloaded and installed OK. Bought a MSI Radeon R9 270x graphics card as per previous topic on black screen after installing,early boot screens but then am left with blank display when Workbench should appear. Mike Brantley purchased the card I have bought after previous one he had did not work XFS R9 270X and said it works fine.
I have the latest radeon drivers installed from amistore.
I have put back my original radeon card and boots fine.
Have gone through all the posts and googled but no luck. In my sys/devs/ monitors I have 4 icons Radeon, radeon HD 6800 series, voodoo and permedia 2. My monitor is a Benq GW2760s 27inch display.
Any ideas from you good folks.
Ax1000/A4000 040 D/A1200 030
ssolie
Re: Black screen after msi Radeon R9 270x installed
Post by ssolie »
Capture the serial output during boot and see if you can find something in there.
See http://wiki.amigaos.net/wiki/Advanced_S ... ging_Guide for more guidance.
electric-magic
Thank you, have ordered the cable from amigakit.
danbeaver
Post by danbeaver »
Does it have two monitor outputs and have you tried them both?
electric-magic
Yes, tried top and bottom dvi ports and the hdmi port.
