Ghost an image
Ghost an image
I have loaded and scaled an image using DataTypes and CompositeTags.
I would like to give it a "ghosted/disabled" look.
I added COMPTAG_SrcAlpha,COMP_FLOAT_TO_FIX(0.75),
It looks ok on some images/colors, but terrible with white images.
Just like when you open Workbench window and do Show All and the C/Devs/S folders are ghosted.
Something simple that can be done on the fly quickly.
- broadblues
Re: Ghost an image
They are not ghosted they are (partially) transparent, subtle and important difference.I have loaded and scaled an image using DataTypes and CompositeTags.
If you realy want ghosted, as in the imagery used for disabled images in gadgets, then I think, bitmap.image can create a ghosted version if the BITMAP_Disabled#? tag is not set. The autgenerated disabled image is a greyscale bumpmap variant on the Render image.
If you want partially transparent then render the image to the destination by blitting with alpha = 0.5 using BlitBitmapTags() (slow for larger images and the alpha blending is not hardware accelerated ) or perhaps CompositeTags()
Re: Ghost an image
Yes, half transparent is what I want. I am having trouble still. All of the error handling has been removed to shorten things up.
Load image
Allocate bitmap and set it up
Create ScaleBM
Scale it and try to make it transparent
Now, if I don't do use the COMPTAG_SrcAlpha tag and use your suggestion to BltBitMapTags(), it locks up. I know the BLIT_Alpha value is not correct, it was just for test and copied from autodoc.
Then put it in a BitMapObject since only showing the images in a listbrowser or button gadget.
I would prefer to do the scaling and transparency all at once with CompositeTags() and not have to use BltBitMapTags() so don't have to use 2 bitmaps (Scale and Ghost).
What would be the correct BLITA_Alpha value if I have to use it? 0x7fffffff or 0x7f7f7f7f maybe?
Load image
if (!(DTO=IDataTypes->NewDTObject(Path,
DTA_GroupID, GID_PICTURE,
PDTA_Screen, DefaultPubScreen,
// PDTA_Remap, FALSE,
// PDTA_AlphaChannel, TRUE,
PDTA_PromoteMask, TRUE,
PDTA_DestMode, PMODE_V43,
// PDTA_WhichPicture, WhichPicture,
TAG_END)))
if (!(OrigBM=IP96->p96AllocBitMap(bmhd->bmh_Width,bmhd->bmh_Height,32,BMF_DISPLAYABLE,NULL,RGBFB_A8R8G8B8)))
Lock=IP96->p96LockBitMap(OrigBM,(uint8 *)&RenderInfoBuffer,sizeof RenderInfoBuffer);
pdtBlitPixelArrayBuffer.MethodID=PDTM_READPIXELARRAY;
pdtBlitPixelArrayBuffer.pbpa_PixelData=RenderInfoBuffer.Memory;
pdtBlitPixelArrayBuffer.pbpa_PixelFormat=PBPAFMT_ARGB;
pdtBlitPixelArrayBuffer.pbpa_PixelArrayMod=RenderInfoBuffer.BytesPerRow;
pdtBlitPixelArrayBuffer.pbpa_Left=0;
pdtBlitPixelArrayBuffer.pbpa_Top=0;
pdtBlitPixelArrayBuffer.pbpa_Width=bmhd->bmh_Width;
pdtBlitPixelArrayBuffer.pbpa_Height=bmhd->bmh_Height;
IIntuition->IDoMethodA(DTO,(Msg)&pdtBlitPixelArrayBuffer);
IP96->p96UnlockBitMap(OrigBM,Lock);
IDataTypes->DisposeDTObject(DTO);
DTO=NULL;
if (!(ScaleBM=IP96->p96AllocBitMap(ScaleWidth,ScaleHeight,32,BMF_CLEAR | BMF_DISPLAYABLE,NULL,RGBFB_A8R8G8B8)))
if (IGraphics->CompositeTags(
COMPOSITE_Src, OrigBM, ScaleBM,
COMPTAG_ScaleX, COMP_FLOAT_TO_FIX(ScaleFactorX),
COMPTAG_ScaleY, COMP_FLOAT_TO_FIX(ScaleFactorY),
!Ghost ? TAG_IGNORE : COMPTAG_SrcAlpha, COMP_FLOAT_TO_FIX(0.75),
// !Ghost ? TAG_IGNORE : COMPTAG_SrcAlpha, COMP_FLOAT_TO_FIX(0.5),
TAG_DONE) != COMPERR_Success)
if (Ghost)
if (!(GhostBM=IP96->p96AllocBitMap(ScaleWidth,ScaleHeight,32,BMF_CLEAR | BMF_DISPLAYABLE,NULL,RGBFB_A8R8G8B8)))
IGraphics->BltBitMapTags(
BLITA_DestX, 0,
BLITA_DestY, 0,
BLITA_Width, ScaleWidth,
BLITA_Height, ScaleHeight,
BLITA_SrcType, BLITT_BITMAP,
BLITA_Source, ScaleBM,
BLITA_DestType, BLITT_BITMAP,
BLITA_Dest, GhostBM,
BLITA_Alpha, 0xfffffff,
// BLITA_UseSrcAlpha, TRUE,
TAG_END);
if (!(Img=BitMapObject,
BITMAP_Screen, DefaultPubScreen,
BITMAP_Precision, PRECISION_EXACT,
BITMAP_BitMap, Ghost ? GhostBM : ScaleBM,
BITMAP_Width, ScaleWidth,
BITMAP_Height, ScaleHeight,
BITMAP_HasAlpha, TRUE,
BITMAP_Masking, TRUE,
BITMAP_Transparent, TRUE, // optional
TAG_DONE)))
- Daytona675x
Re: Ghost an image
For the most common "I want a pretty simple semi-transparent blit over other stuff" IGraphics->CompositeTags(COMPOSITE_Src_Over_Dest,...); is probably what you're looking for.
Warp3D driver code-basher and bug-smasher - btw.: driver writing is nothing mysterious
- broadblues
Re: Ghost an image
Bitmap Image can do the scaling for you, and also transparency via a seperate AlphaBitmap see the autodoc.Then put it in a BitMapObject since only showing the images in a listbrowser or button gadget.
If you have large number of images that are dramatical scaled down that might be a bit expensive in memory, so you might prescale using compositetags (or other methods )
Re: Ghost an image
.......and if I knew how to make a custom bitmap with transparency only I wouldn't have posted the original message......
2) Again, have an example????
Probably. Have an example???IGraphics->CompositeTags(COMPOSITE_Src_Over_Dest,...); is probably what you're looking for.
1) I posted code doing that.1) so you might prescale using compositetags (or other methods )
2) Bitmap Image can do the scaling for you, and also transparency via a seperate AlphaBitmap see the autodoc.
Re: Ghost an image
I figured out a "hack" way to do it. I made a 50% transparent PNG image, just a blank image, load it and use COMPOSITE_Src_Over_Dest to put it over the actual image.
In the code above I use p96AllocBitMap() to create my bitmap. Anyone have an example to how to use p96WritePixelArray() to fill it with a 50% transparent alpha channel only (no RGB, just A)? Then I don't have to use the external PNG image.
- broadblues
Re: Ghost an image
What is wrong with the following loop:mritter0 wrote:I figured out a "hack" way to do it. I made a 50% transparent PNG image, just a blank image, load it and use COMPOSITE_Src_Over_Dest to put it over the actual image.
Load image
Foreeach pixel:
ReadPixel
Divide Alpha Part by 2
Write Pixel back (or to a second bitmap to cache the resulst)
Reander image with bitmap.image as normal.
Your talking small icons IIRC so hardware accelleration is not 100% required especially if you ultimatelt render to screen with bitmap.image.
- broadblues
Re: Ghost an image
If you want to write alpha data into a bit map then you do something like this:
Allocate array of RGBFB_ALPHA8 pixels (basically 8 bits per pixlel o alpha only)
Copy your alpha data from your src (or explixitly set it by alpgorithm if you are generating it on the fly)
Fill out this structure
struct RenderInfo {
APTR Memory;
WORD BytesPerRow;
WORD pad;
RGBFTYPE RGBFormat;
Us P96WritePixelArray() to copy into your bitmap, which should then only modify the alpha (but testing required to chack that).
If you destination is also RGBFB_ALPHA8 you can use that with bitmap.image but I think this *replaces* the alpha information rather than multiplying it so you will need to start from the alpha map of your icon image (if it has one), so you are back with my loop above.
struct RenderInfo {
APTR Memory;
WORD BytesPerRow;
WORD pad;
RGBFTYPE RGBFormat;
Re: Ghost an image
I worked out a good method for my use. p96AllocBitMap(), AllocVecTags() a chunk of memory, fill it with 50% alpha only, p96WritePixelArray(), and keep using the COMPOSITE_Src_Over_Dest method in my "hack".
