with my AmigaOne X1000 which runs AmigaOS 4.1 FE,
dragging the "DateTime.docky" Docky (System:Utilities/Dockies/DateTime.docky) on the Dock, appears the following error:
"Warning: Can't read/loadf XML settings (error: 0x00008000)".
Why?
Then,
this message appears at every boot of the machine.
There are links with this thread? http://forum.hyperion-entertainment.biz ... 2321&hilit
AmigaONE X1000, AmigaOS 4.1 FE & DateTime.docky
- Amiga Supremo
...A good friend of flew on the Commodore Jet to Irving Gould's house in the Bahamas in about 1996. At that time Irving Gould was alive and well living in retirement and was believed to still be a Canadian citizen. Go CANADA!!!
Re: AmigaONE X1000, AmigaOS 4.1 FE & DateTime.docky
What is this "DateTime.docky"? Where does it come from? Is it a system component, or something you have installed as a third-party component?
@Amiga Supremo
Contact the author Jabirulo (Javier).
His mail adress is here :
http://os4depot.net/?function=showfile& ... _docky.lha
- Amiga Supremo
@ tonyw
"DateTime.docky" is a third-party component.
@ zzd10h
Ok,
thanks for the tip.
@ zzd10h
Ok,
thanks for the tip.
There's also some mention of this issue in the comments on OS4Depot: http://os4depot.net/?function=comments& ... _docky.lha
- Amiga Supremo
Hi nbache,
thanks a lot for your reply!
I had not seen the comments on OS4DEPOT; sorry.
Now I solved by creating the "DateTime.docky.xml" missing file.
