How to read status from Ethernet interface
I know how to read the speed, but how do I check duplex and negotiation on an ethernet interface? In first hand for the Sam440ep-Flex machine.
- javierdlr
Re: How to read status from Ethernet interface
Try http://os4depot.net/index.php?function= ... ometer.lha and it comes with sources
Thank you. Actually that's the program I'm currently enhancing and is partly the reason for my question.
Try looking here:
http://wiki.amigaos.net/wiki/SANA-II_Revision_7
If you still can't find anything we'll need to bother Olaf (Roadshow) to find out what he did.
I just did 20 seconds before reading your message.ssolie wrote:Try looking here:
But unfortunately it doesn't mention duplex or auto-negotiation. I guess the driver should (and probably is) take care of it, but the SANA stuff should be able to at least display settings if not being able to configure it.
I guess Olaf is the first to talk to and maybe second, Acube.
All this - Duplex and AutoNeg - is done at driver level. The TCP/IP stack and also no other software has any idea about this. There is also no way to get that information from the driver, at least not an officially defined way, so if a driver provides this, it is a private extension to that specific driver.
Please contact [email protected] rather than trying to send PMs to me. Thanks!
Okay, thanks. You may see it as a feature request then.Cyborg wrote:All this - Duplex and AutoNeg - is done at driver level. The TCP/IP stack and also no other software has any idea about this. There is also no way to get that information from the driver, at least not an officially defined way, so if a driver provides this, it is a private extension to that specific driver.
Ah good. We do need more people to help work on the SANA-II standard. Welcome aboard!duga wrote:Okay, thanks. You may see it as a feature request then.Cyborg wrote:All this - Duplex and AutoNeg - is done at driver level. The TCP/IP stack and also no other software has any idea about this. There is also no way to get that information from the driver, at least not an officially defined way, so if a driver provides this, it is a private extension to that specific driver.
