Cx locks WB
Cx locks WB
In my project I use the screen notify system for when WB wants to close/reopen. All worked fine until I added a little commodity to my project. It seems to lock the screen and prevents WB from completing its update. Is this normal? Do I have to shut down the Cx and re-open? If I don't start the Cx at program start it works as expected. The Cx just listens for 2 rawkeys.
Re: Cx locks WB
If you open Exchange you will see a number of commodities that don't block WB from close/reopen. In the case of those that can open a window, there is blocking when the window is open. If your commodity isn't opening a window then there should be a way of preventing it from blocking WB open/close.mritter0 wrote:In my project I use the screen notify system for when WB wants to close/reopen. All worked fine until I added a little commodity to my project. It seems to lock the screen and prevents WB from completing its update. Is this normal? Do I have to shut down the Cx and re-open? If I don't start the Cx at program start it works as expected. The Cx just listens for 2 rawkeys.
Re: Cx locks WB
Its weird. I have verified the PubScreen is unlocked. Disable the Cx it works fine. I will keep plugging away at it. It can't be a bug since, like you said, there are other Cxs running that work. Has to be on my part.
- salass00
Re: Cx locks WB
It might be worth for you to try and isolate the problem code into a smaller test program. If it turns out to be a system bug rather than just a mistake on your part then this will also be useful as a test case for when fixing it.mritter0 wrote:Its weird. I have verified the PubScreen is unlocked. Disable the Cx it works fine. I will keep plugging away at it. It can't be a bug since, like you said, there are other Cxs running that work. Has to be on my part.
Re: Cx locks WB
I found a couple of example commodity programs on the old developer CD, modified them slightly to compile for OS4 and tested them. Neither one prevents Workbench from closing and reopening. If you have access to a developer CD, the examples are Broker.c and PopShell.c. Maybe you can compare what you're doing with the way those examples work. If you figure out the problem let us know because I have an old program that also blocks WB open/close which might be commodities related.mritter0 wrote:Its weird. I have verified the PubScreen is unlocked. Disable the Cx it works fine. I will keep plugging away at it. It can't be a bug since, like you said, there are other Cxs running that work. Has to be on my part.
Re: Cx locks WB
I figured it out. When the window was closed it tried to re-open it before it should have. I had to put several little checks in the code to figure it out. Thanks for the input. It made me look at things closer and found another error, also.
Re: Cx locks WB
I found the real problem: I was using bit SNOTIFY_WAIT_REPLY along with SNOTIFY_BEFORE_CLOSEWB and SNOTIFY_AFTER_OPENWB. Took out SNOTIFY_WAIT_REPLY like AutoDocs says not to use and it works much better.
