DOS putting a scrpts argument in a requestedfile
JosDuchIt
Post by JosDuchIt »
I don't see a direct DOS possibility to first get some argument & then put it in a file the user choses
I came up with
KEY VAR/A
.BRA {
.KET }
RequestFile ram: TITLE "VARfileName" to t:.VAR_File
echo "{VAR}" >`type t:.VAR_File`
the file is created but gets no content.
whereas from the shell
echo "mycontent" >`type t:.VAR_File`
will work.
Solution?
Re: DOS putting a scrpts argument in a requestedfile
.key VAR/A
.bra {
.ket }
set filename `requestfile`
echo "{VAR}" >"${filename}"
JosDuchIt
Post by JosDuchIt »
@broadblues
yes, of course,
thanks
JosDuchIt
Post by JosDuchIt »
@BroadBlues
I don't know if it is the heat ir, but after an initial test of the script that worked correctly ,
i used a more complex command line and got the error message "RequestFile not executable"
After that even from the shell you got
7.Stock:MultiViewer> RequestFile
RequestFile: file is not executable
and even after a SW reboot that remained the case
I gradually simplified to get to the original command, to no avail
I can input a filename string with requeststring, but lck viual feedback then.
Do you observe something similar?
KEY VAR/A
.BRA {
.KET }
set filename `requeststring Title "chose name" Body "" DefString "t:Lists_I_URL/"`
;// set filename`RequestFile t:Lists_I_URL TITLE "Select Name under which image should be recognised " ` ;// requestFile becomes not executable
;//set filename`RequestFile DRAWER t:Lists_I_URL TITLE "Select Name under which image should be recognised " `
;// set filename`RequestFile DRAWER t:Lists_I_URL TITLE "Select Name " `  ;// requestFile becomes not executable
set filename`RequestFile  `  ;// requestFile still not executable
; //set filename `requestfile`
Post by thomasrapp »
Enter
which requestfile
to check where it is loaded from.
Don't call your script requestfile.
@thomasrapp
I notice the " | " (bar character) in his commands. That character is described as relating to a pipe in some AmigaDOS documentation. Could his commands be "accidently" using a pipe with dangerous results? I have never found an example of using the "|" char so I could be wrong about this.
JosDuchIt
Post by JosDuchIt »
@thomas
Some empty file RequestFile was created in my script's drawer.
Thanks for the suggestion
@Xenix the character is not a | but i majuscule Ilist, thanks for your examination
