Update 3 : Problem with a mouse
NoRdWiNd
Post by NoRdWiNd »
Insignificant little problem, but maybe it can be useful.
My mouse worked perfectly with update 2, with the installation of update 3 is unusable, even changing all possible settings, all USB ports. the pointer is fast vertically, horizontally is very slow. With another mouse works perfectly with any update.
460EX 1Ghz - 2 Gb Ram - 9250 128 Mb
ChrisH
Re: Update 3 : Problem with a mouse
Post by ChrisH »
Try modifying the "Sys:Kickstart/Kicklayout" as i describe here:
http://forum.hyperion-entertainment.biz ... yout#p3959
Make sure you back-up the original Kicklayout file!
NoRdWiNd
Post by NoRdWiNd »
Yes! Yours is the solution, now also works the other mouse!
Thank you !
