mrupp
Posts: 42 Joined: Sat Jun 18, 2011 1:19 pm
Post
by mrupp » Sun Jun 21, 2015 12:31 pm
Hi
I'd be glad if somebody could confirm this (and file a bug report or something): On both of my 4.1FE systems (X1000, Sam440flex) the following command crashes the task with a Grim Reaper, DSI error:
version sobjs:libjpeg.so
I tried again with the one from 4.1u6 where the output is
VERSION: Could not find version information for "SObjs:libjpeg.so".
The file from 4.1FE has the same size (1.167.242 bytes) but a newer date (08-Oct-14) compared to the one from 4.1u6.
BTW: By replacing the file with the older one I got Hurrican to run again.
Greetings
Michael
Check out TAWS - The Amiga Workbench Simulation
https://taws.ch
eliyahu
Posts: 63 Joined: Sat Jun 18, 2011 12:13 am
Post
by eliyahu » Sun Jun 21, 2015 5:30 pm
mrupp wrote: I'd be glad if somebody could confirm this (and file a bug report or something): On both of my 4.1FE systems (X1000, Sam440flex) the following command crashes the task with a Grim Reaper, DSI error:
i can confirm this is the case on my pegasos2 and X5K systems. i cannot open a BZ, however, since libjpeg doesn't appear as a component in the BZ system. so i'll pester someone when i get a chance. in the mean time, here is a copy of the GR crash log from my system. it looks like c:version gets stuck in a very long loop searching for the version string.
Crash log for task "version"
Generated by GrimReaper 53.19
Crash occured in module kernel.debug at address 0x01876DE0
Alert number: 0x80000003
Register dump:
0: 01994310 4E229010 00000002 6FFFE300 4E229020 4E2290E8 6FFABB40 4E714EF9
8: 00000018 01876DE0 4E229148 00000000 019862BC 0000000D 4E21C9B4 5EC8F490
16: 00000001 00000001 4E23830C 4E2382D6 00000001 02035D14 6FFABB40 0000002A
24: 5EB30588 5EB304A0 00000444 0218266C 02160000 80000001 6FFABAD4 6FFFE300
0: nan nan 0 0
4: 0 0 1 2.14748e+09
8: 128 1 1 0.029453
12: 0 -4.29497e+09 5.37866e-168 -3.46816e+116
16: -2.29247e-276 4.10009e-262 -1.49024e-242 -6.13581e-243
20: 1.14773e+99 -1.31639e+19 -5.33486e+271 1.29299e-267
24: 4.03812e+89 -2.57432e+20 -3.70638e+54 -2.92633e+64
28: 0 0 1.43492e+09 1.43492e+09
FPSCR (Floating Point Status and Control Register): 0xA3008000
Machine State (msr) : 0x0002D030
Condition (cr) : 0x51C3C0F8
Instruction Pointer (ip) : 0x01876DE0
Xtended Exception (xer) : 0x567520D4
Count (ctr) : 0x51C3C0F8
Link (lr) : 0x0002000E
DSI Status (dsisr) : 0x567520D4
Data Address (dar) : 0x51C3C0F8
680x0 emulated registers:
FPU0: 0 0 0 0
FPU4: 0 0 0 0
Symbol info:
Instruction pointer 0x01876DE0 belongs to module "kernel.debug" (HUNK/Kickstart)
Stack trace:
native kernel module kernel.debug+0x00076de0
native kernel module kernel.debug+0x000768c8
native kernel module elf.library.kmod+0x00001828
native kernel module elf.library.kmod+0x00001b9c
native kernel module elf.library.kmod+0x00004ba0
native kernel module elf.library.kmod+0x00001be4
native kernel module elf.library.kmod+0x00005904
native kernel module elf.library.kmod+0x00000d54
native kernel module elf.library.kmod+0x000002f0
native kernel module dos.library.kmod+0x00041dcc
native kernel module dos.library.kmod+0x0001b6ac
module version at 0x7F8AAE10 (section 5 @ 0xDEC)
module version at 0x7F8AB26C (section 5 @ 0x1248)
module version at 0x7F8ABCF8 (section 5 @ 0x1CD4)
version:_start()+0x1d0 (section 1 @ 0x1EB4)
native kernel module dos.library.kmod+0x000255b0
native kernel module kernel.debug+0x00068a84
native kernel module kernel.debug+0x00068acc
PPC disassembly:
01876dd8: 80c10020 lwz r6,32(r1)
01876ddc: 4bfffedc b 0x1876CB8
*01876de0: 9421ffe0 stwu r1,-32(r1)
01876de4: 7c0802a6 mflr r0
01876de8: 93c10018 stw r30,24(r1)
System information:
CPU
Model: Freescale P50XX (E5500 core) VV1.2
CPU speed: 1995 MHz
FSB speed: 798 MHz
Extensions:
Machine
Machine name: AmigaOne X5000/20
Memory: 2097152 KB
Extensions: bus.pci bus.pcie
Expansion buses
PCI/AGP
00:00.0 Vendor 0x1957 Device 0x0421
01:00.0 Vendor 0x1002 Device 0x683F
Range 0: 80000000 - 90000000 (PREF.MEM)
Range 2: 90000000 - 90040000 (MEM)
Range 4: 00001000 - 00001100 (IO)
01:00.1 Vendor 0x1002 Device 0xAAB0
Range 0: 90040000 - 90044000 (MEM)
02:00.0 Vendor 0x1957 Device 0x0421
03:00.0 Vendor 0x111D Device 0x8092
04:01.0 Vendor 0x111D Device 0x8092
04:02.0 Vendor 0x111D Device 0x8092
04:03.0 Vendor 0x111D Device 0x8092
04:08.0 Vendor 0x111D Device 0x8092
04:10.0 Vendor 0x111D Device 0x8092
05:00.0 Vendor 0x12D8 Device 0xE111
06:04.0 Vendor 0x10EC Device 0x8139
Range 0: 00001000 - 00001100 (IO)
Range 1: A0000000 - A0000100 (MEM)
06:05.0 Vendor 0x1095 Device 0x3114
Range 0: 00001100 - 00001108 (IO)
Range 1: 00001108 - 00001110 (IO)
Range 2: 00001110 - 00001118 (IO)
Range 3: 00001118 - 00001120 (IO)
Range 4: 00001120 - 00001130 (IO)
07:00.0 Vendor 0x1B21 Device 0x1080
08:00.0 Vendor 0x1412 Device 0x1724
Range 0: 00002000 - 00002020 (IO)
Range 1: 00002080 - 00002100 (IO)
-- eliyahu
eliyahu
Post
by eliyahu » Sun Jun 21, 2015 5:50 pm
@thread
i've opened a defect against the version command in the interim. it has been posted to the development team as BZ #9237. a big thanks to @mrupp for reporting it!
-- eliyahu
Posts: 1185 Joined: Sun Jun 19, 2011 1:06 am
Post
by xenic » Sun Jun 21, 2015 6:50 pm
eliyahu wrote: @thread
-- eliyahu
Apparently, the data in the first 56 bytes of libjpeg.so is being recognized as a library or device header. If I cut out the first 56 bytes of libjpeg.so and save it as a file, version will also fail on that file. You may want to mention the specific file that version is failing with in the BZ.
Post
by xenic » Sun Jun 21, 2015 6:57 pm
mrupp wrote: Hi
I can confirm the bug. I tested all the SObjs and libicudata-3.4.so also causes the version command to fail. The data in the first 56 bytes of libicudata-3.4.so looks the same as or similar to the first 56 bytes of libjpeg.so. I think the "version" command is erroniously recognizing both SObjs as Amiga shared libraries (xxx.library).
eliyahu
Post
by eliyahu » Sun Jun 21, 2015 8:24 pm
@xenic
thanks for the feedback. i've updated the ticket.
-- eliyahu
mrupp
Post
by mrupp » Sun Jun 21, 2015 8:34 pm
@eliyahu
I think there's something wrong with libjpeg.so as well (or maybe even in the first place), so the case should also be against libjpeg.so. The whole story is, that I tried to get Hurrican 1.0.0.9 running on my 4.1FE systems for it stopped working with the 4.1 Final Edition. It was more by accident that I found out about the crash by the version command. It's the same DSI crash when running Hurrican. After replacing libjpeg.so with the one from 4.1u6, Hurrican works again and so does the version command on the older libjpeg.so. So it looks to me, that the DSI occurs as soon as the 4.1FE libjpeg.so is allocated.
https://taws.ch
samo79
Posts: 580 Joined: Sat Jun 18, 2011 12:13 am
Post
by samo79 » Mon Jun 22, 2015 12:05 am
@mrupp
Great found, thank you !
I can confirm the issue as the library crash also on my system .. atleast we can play with Hurrican again
SOFISTISOFTWARE
Posts: 44 Joined: Sat Jun 18, 2011 9:14 am
Post
by SOFISTISOFTWARE » Mon Jun 22, 2015 2:54 pm
@mrupp
Thank you very much indeed ! A very useful tip, now Hurrican works again on my Saam460 and os4.1fe
Sam 460EX, 2Gb Ram, Radeon R7 250E, OS4.1 FE
Post
by xenic » Mon Jun 22, 2015 5:07 pm
mrupp wrote: @eliyahu
If there is something wrong with libjpeg.so then libicudata-3.4.so is probably bad too. It has the same bad data which causes the version command to fail.
