MUI-OWB and update3: MUImaster.library DSI
Mrodfr
Post by Mrodfr »
Found a DSI:
Reproducable with MUI-OWB and Update3
- on favori MUI window (yellow star), you add a group (ex. amiga).
- Inside you create or drag a link (ex. amigaworld).
- Inside you create or drag another link (ex.AMINET).
- you open the favory (yellow star).
- you open the group amiga
- you drag AMINET to be the first one and amigaorld the second one.
- you close the favory MUI window
- you try to open again the favory MUI window with the yellow star.
The window not arrive and a DSI. Reproducable 100%.
Hidden Text - Click to Show :
Symbol info:
Instruction pointer 0x6E739104 belongs to module "muimaster.library" (PowerPC)
Symbol: m_Rectangle_AskMinMax + 0x180 in section 1 offset 0x000710E4
Stack trace:
m_Rectangle_AskMinMax()+0x180 (section 1 @ 0x710e4)
RectangleDispatcher()+0x170 (section 1 @ 0x71848)
native kernel module intuition.library.kmod+0x00018178
native kernel module intuition.library.kmod+0x0001839c
native kernel module intuition.library.kmod+0x00008424
native kernel module intuition.library.kmod+0x00008064
MUIP_AskMinMax()+0x44 (section 1 @ 0x103e4)
m_Group_AskMinMax()+0xA4 (section 1 @ 0x3f164)
GroupDispatcher()+0x4B4 (section 1 @ 0x46668)
CalcMinMax()+0x88 (section 1 @ 0x87230)
WindowDispatcher()+0xB64 (section 1 @ 0x928ac)
native kernel module intuition.library.kmod+0x000082dc
OWB:_ZL8dispatchP6IClassPmP4_Msg()+0x8C (section 1 @ 0x3853c)
CustomClassDispatcher()+0xA0 (section 1 @ 0x40d8)
m_Group_ExitChange()+0xF0 (section 1 @ 0x3efa0)
GroupDispatcher()+0x6F0 (section 1 @ 0x468a4)
ListDispatcher()+0x152C (section 1 @ 0x5a7a8)
Listtree.mcc:_Dispatcher()+0x554 (section 1 @ 0x9c58)
OWB:_ZL8dispatchP6IClassPmP4_Msg()+0x98 (section 1 @ 0x41c74)
m_List_Setup()+0x280 (section 1 @ 0x51fd4)
ListDispatcher()+0x288 (section 1 @ 0x59504)
Listtree.mcc:_Setup()+0x5C (section 1 @ 0x6660)
Listtree.mcc:_Dispatcher()+0x1158 (section 1 @ 0xa85c)
MUIP_Setup()+0x44 (section 1 @ 0xecdc)
m_Group_Setup()+0x74 (section 1 @ 0x3e0ec)
GroupDispatcher()+0x7F8 (section 1 @ 0x469ac)
ListviewDispatcher()+0x34C (section 1 @ 0x5d5e8)
OWB:_ZL16handleMUIM_SetupP6IClassPmP10MUIP_Setup()+0x58 (section 1 @ 0x3c9a4)
RootgrpDispatcher()+0x6C (section 1 @ 0x72b14)
OpenTheWindow()+0x2AC (section 1 @ 0x8b624)
m_Window_SET()+0x187C (section 1 @ 0x90944)
WindowDispatcher()+0xD50 (section 1 @ 0x92a98)
native kernel module intuition.library.kmod+0x0001870c
native kernel module intuition.library.kmod+0x00007f14
native kernel module intuition.library.kmod+0x000081b4
OWB:_ZL26handleMM_OWBApp_OpenWindowP6IClassPmP20MP_OWBApp_OpenWindow()+0x70 (section 1 @ 0x3250)
OWB:_ZL8dispatchP6IClassPmP4_Msg()+0x5D0 (section 1 @ 0xcb84)
m_Notify_SET()+0x6D4 (section 1 @ 0x63cf0)
m_Area_SET()+0x260 (section 1 @ 0x2fc38)
m_Group_SET()+0x55C (section 1 @ 0x44750)
GroupDispatcher()+0xE48 (section 1 @ 0x46ffc)
OWB:_ZL12handleOM_SETP6IClassPmP5opSet()+0x70 (section 1 @ 0x34040)
OWB:_ZL8dispatchP6IClassPmP4_Msg()+0x54 (section 1 @ 0x5783c)
OWB:_ZL22handleMUIM_HandleInputP6IClassPmP16MUIP_HandleInput()+0x410 (section 1 @ 0x34474)
GroupDispatcher()+0xC24 (section 1 @ 0x46dd8)
OWB:_ZL8dispatchP6IClassPmP4_Msg()+0x9C (section 1 @ 0xeeb4)
SendIMsgs()+0x254 (section 1 @ 0x88d50)
m_Window_Input()+0x864 (section 1 @ 0x8d55c)
m_Application_NewInput()+0x8C8 (section 1 @ 0x24a08)
ApplicationDispatcher()+0xD4C (section 1 @ 0x29390)
OWB:_ZL8dispatchP6IClassPmP4_Msg()+0x150 (section 1 @ 0xc704)
OWB:_Z9main_loopv()+0x84 (section 1 @ 0x1034)
OWB:main()+0x12C (section 1 @ 0x134c)
native kernel module newlib.library.kmod+0x00002054
native kernel module newlib.library.kmod+0x00002ce8
native kernel module newlib.library.kmod+0x00002e64
OWB:_start()+0x170 (section 1 @ 0x170)
native kernel module dos.library.kmod+0x00020a14
native kernel module kernel+0x0003af4c
native kernel module kernel+0x0003afcc
PPC disassembly:
6e7390fc: 80fd001c lwz r7,28(r29)
6e739100: 80be0004 lwz r5,4(r30)
*6e739104: 81270018 lwz r9,24(r7)
6e739108: a8050000 lha r0,0(r5)
6e73910c: 5524f7fe rlwinm r4,r9,30,31,31
abalaban
Re: MUI-OWB and update3: MUImaster.library DSI
Post by abalaban »
@Mrodfr
For such long text copy/paste you can use the 'hidden' button on top of the text editing area. This adds a foldable/unfoldable text which is much more friendly when browsing the post.
Anyway I only briefly had the opportunity to test MUIOWB yesterday and I didn't come accross this problem. I'll try this evening.
AmigaOne XE/G4
Mrodfr
Post by Mrodfr »
Hello,
In fact, I think now this problem appeared only with a blank MUI-OWB bookmarks.html file.
I have added all my Ibrowse links now and I can't reproduce the problem.
kas1e
Post by kas1e »
@mrodfr
Better if you will send all the problems about mui-owb to me (even if crash logs points on mui), because its really 3d party app and not hyperion's one.
