Ubuntu Mate 15.10
Ubuntu Mate 15.10
Hi
I tested the installation of ubuntu mate 15.10.
Installation went well.
booted to the login prompt ,then logged in and created an xorg.conf
file.
Then sudo service lightdm start and then joined the graphic's login.
Here login failed with this errror : startup of the session failed.
Tried to install another desktop instead of Mate but got this error
Temporary errors when setting up ports.ubuntu.com.
Re: Ubuntu Mate 15.10
It seems that the problem is a question of rights. get an error that says
can not create / sys / module / snd_hda_intel / parameters / power_save: permission denied.
Then the system freezes .
The problem: Temporary errors when setting up ports.ubuntu.com, was an error with the network
I gave up Mate 15.10 and installed Xubuntu. Then I installed christians Mesa and downgraded xorg.
All work fine but modules are not loaded. I expect it to be resolved. Xubuntu is here booted with RC8.
musa wrote:I gave up Mate 15.10 and installed Xubuntu. Then I installed christians Mesa and downgraded xorg.
Hi Musa,
Thank you very much for testing! I'll try to update my ubuntu MATE 15.04 to 15.10.
Rgds,
I could update my ubuntu MATE 15.04 to 15.10 successfully today. The new Xorg server shows all colors correct. Unfortunately Compiz doesn't work currently.
Fantastic! Compiz works on ubuntu MATE 15.10 again.
xeno74 wrote:Fantastic! Compiz works on ubuntu MATE 15.10 again.
Ubuntu Mate 15.10 with vmlinux-4.1.3 and updated
Compiz works
There are still some wrong colour in cairo-dock
Look like it is only in svg icons. not in png
Compiz works
Thank you very much for testing. :-)
After a big update today I found two problems in ubuntu MATE 15.10 PowerPC today.
The first is systemd. If I start ubuntu MATE 15.10 with systemd then the gnome-settings daemon doesn't start and MATE Tweak doesn't work (see screenshot). If I use upstart-sysv then MATE Tweak and the gnome-settings-daeomon work without any problems.
Additionally there is a problem with MATE Tweak itself. If I switch to Compiz then it set org.gnome.metacity theme to 'Ambiant-MATE'. Metacity can't display the window decoration with the two apostrophes in the theme name (see screenshot).
I created an own script to switch to Compiz and I set the theme name without apostrophes:
gsettings set org.gnome.metacity theme Ambiant-MATE
compiz --replace
This works very well.
Rgds,
I have released the RC4 of kernel 4.2 recently.
- systemd support (You don't need the boot argument "rw" for ubuntu MATE 15.04 and 15.10 anymore.)
Other changes:
https://git.kernel.org/cgit/linux/kerne ... x.git/log/
Linux 4.2-rc4 Released, But 4.2 Isn't Quite Calming Down - phoronix
The Linux 4.2-rc4 release announcement at LKML.org
- KVM_BOOK3S_64_PR
- Mac-on-Linux support
- Network support for AROS hosted
- Support for 4 serial ports
- Bluetooth USB dongle support
- Kernel tracing with ftrace
- ubuntu MATE 15.04 and 15.10 support
- Debian 8 support
- Linux kernel icon for OS4.1 by Tommysammy
Download: vmlinux-4.2-rc4-AMIGA_one_X1000.tar.bz2
