Why in the workd does this happen sometimes to me???
http://scacom.bplaced.net/aos4/20150412_213647.jpg
This pic Comes instead of the black/Grey Kickstart Thing. It will Change Colors from time to time and the boot Sound will Play, but you never can reach workbench, it just does not disappear.
I have a Amiga ONE 500, SAM 460 EX (not CR), Toshiba 2 TB HDD, 2 GB RAM, Radeaon Graphics Card and SATA port Card. I have a clean new install of Amiga OS 4.1 Update 6 on my HDD as HD0: parition with SFS/00 (block size512 was recommended to me). This Hardware configuration was sold officially by Amiga dealer.
I had a lot of trouble with blck size 1024 like it was delivered (I bought it used but the guy owning it before never changed anything and had Update 2 on it still).
So I am angry that this happens all the time why cant it boot reliable??? Sometimes it works and sometimes not. Someone paid over 1000 Euros for this? Really? I am a but upset by it all. Sound is not configured right, USB not always working, etc. Who did beta test this? I am the first one? Sorry but this really is so annoying.
Please help.
Why in the world boot with 16 colors?
Re: Why in the world boot with 16 colors?
I have seen this on my XE when the gfx driver was crashing...
Do you have a serial cable and the possibility to log the boot process?
Did you try stripping the machine to the bare minimum (hdd, gfx board) to see if the crash persists?
There can be many reasons why it' s acting up like that, there might be one of the cards you have dying (or cold soldering or something), RAM problems, maybe even your PSU...hard to tell.
Try to strip it down and step by step find out why it' s doing that.
A sertial log would be most helpful right now
BTW: Welcome to the forums
It might be because it's used hardware and the guy selling it to you "forgot" to tell you about certain flaws it's suffering?So I am angry that this happens all the time why cant it boot reliable??? Sometimes it works and sometimes not.
Don't blame the developer, blame the first userSound is not configured right, USB not always working, etc. Who did beta test this? I am the first one? Sorry but this really is so annoying.
Camiga:
You can be sure that it was not like that when it was delivered. Either the previous owner has screwed up the installation, you have accidentally changed something or the updates from Update 2 to Update 6 have failed.
Since you can't be sure of what is there, I would suggest that you perform a new clean installation of OS 4.1. The best thing to install would be Final Edition, but if you are reluctant to spend another EU30, then you will have to go through a clean install of Update 1 and then do all the updates 2, 3, 4, 5, 6, testing at each stage. You can't install Update 6 over Update 1, 2, 3, or 4, all the previous updates have to be done first.
The Final Edition is a much safer choice. Start with a new clean partition (500 MB is quite big enough for the system), format it with SFS\0 and 512-byte blocks, then install the system into that.
When you have a working system, make another partition for all your "stuff". Don't put it on the system partition, leave that clean so that you can update it easily in the future.
Hello,
Thank you. I hope I can get it to work.
OK, how can I make that work?
Well not that easy now. How can I do that? Connect it with an Amiga 500?
No. I did not connect anything anyways, all t has is graphic Card and SATA Card, HDD and DVD.
Hey, that is me
Well all new, rarly used stuff.
Maybe I can try without graphics Card but why did I buy it when I cannot use it?
Thank you.
TONYW
Well it was devlivered like that with wrong file System, always throwing DSI-error (Data storage Interrupt) when copying files or launching RunInUAE. The previous owner did NOTHING with it except to boot it up a few times. He did not install anything, and he told me OS came installed like I got it.
I then updated from Update 2 to 3, 4, 5, 6. I booted everytime in between updates. It always worked, except update 6 (first boot = 16 Colors).
I did yesterday. First boot with Update 6 = 16 Colors.
> install of Update 1
I do not have Update 1. The CD is called "Amiga 4.1 OS Update 2". How can I get Update 1?
I did.
I did. HDD Partition 1 is 50 GB. I have 2 TB at all (5 Partitions)
I will do. But I want it to work.
Any help appreciated. I will try around more. Always when this error Comes, the Screen says "no Signal" for a short time. If you reboot then, it will mostly work. I do not get it why it works one time and not other time.
Camiga
Hey, that is me
Thank you.
TONYW
> install of Update 1
I did.
Camiga
I'm with Tony here...spend the 30 € to get yourself AmigaOS4.1 FE, drop all the other versions and updates and install FE to a fresh partition.
You'll have much less grey hair to puill out
You shouldn't need to. Tony misremembers, I think, it should be okay to start with Update 2, which is a full install CD.Camiga wrote:I do not have Update 1. The CD is called "Amiga 4.1 OS Update 2". How can I get Update 1?
But after that, you will have to struggle with all the other updates one at a time - or make it easy and buy ... well, it's already been said and repeated
