Joypad/Joystick issue on AmigaOS 4.1 FE
reflex79
Post by reflex79 »
Hello,
I successfully installed AmigaOS 4.1 FE on my amiga 4000 but I had some troubles, exactly I cannot use my honeybee joypad to play with wipeout 2097, it seems not to ben seen by the OS, is there anything I have to configure in order to use it?
MMikhail
Re: Joypad/Joystick issue on AmigaOS 4.1 FE
Post by MMikhail »
Same problem, you cant configure AmigaInput for classic CD32 pad under 4.1FE!
Why?
There is no drivers included!
Ok, you can find some on previous versions of OS4, but that's unfair since you don't get the all in one package that 4.1FE promised.
After getting the drivers, you still get in trouble to configure it.
Trying it with mini Slug game, the config tool kind of works, but the game refuses to accept the joystick and disabled it.
The lowlevel lib test tool from OS3 shows that it kind of working but incorrectly, maybe there is a test tool for OS4 to test the joypad movement?
AmigaInput does not seem to offer anything.
A1260T/BPPC/BVPPC/128MB/CNET/SCSI/HDD/CDRW/DVD/HPLJ4P/HPSJ6 (AMiGA)
reflex79
Post by reflex79 »
the bad is that I only have OD 4.1 FE and no prevous versions, so basically I cannot play to any game launched from the workbench... very bad thing.
reflex79
Post by reflex79 »
hello, any progress on this subject?
I posted this thread almost 7 years ago and gave up on AmigaOS 4.1FE classic for this and other issues, now I'm trying agin and hopes that this was solved!
