list | more broken (?)
First of all...THANK YOU very much for the great update :-D
It feels faster, even more stable and it's just awesome to be able to install it without a complete new install. KUDOS!
Now for a simple misbehaviour i found.
list | more should list the files, stop when the shell's window bottom is reached and show the rest or next page when the user presses a key...
with update 3 none of this happens, instead the shell window is blanked and somehow "frozen"...i can move it around, resize, put to background, get it back to front and such but i cannot close it for my life :-)
It just stays there and probably waits for something ;-)
Anyone can reproduce that?
Is it a regression?
PIPE is in Devs:/DOSDrivers, but i assume there was a change in L:queue-handler which triggers this behaviour, no?
Thank you very much again
Oh...it worked in update 2
People are dying.
How dare you!
– Greta Thunberg
abalaban
Re: list | more broken (?)
Post by abalaban »
@Raziel
'xxx | more' always behave a bit strangely (IMHO, or at least compared to how someone used to the Unix feature would expect it to work). In practise I found myself using more and more the 'recorder' command line and then a 'more' or 'EditPad' on the result.
In the meantime this might be of some to you :?:
AmigaOne XE/G4
abalaban wrote:@Raziel
I need to try that recorder thingie :-)
Normally on large texts i do a list xxx >ram:xxx.txt and then read it with all the time i have ;-)
...still, this command shouldn't lock up the shell, should it? :-)
People are dying.
How dare you!
– Greta Thunberg
abalaban
Post by abalaban »
Raziel wrote:I need to try that recorder thingie :-)
Advantage of using recorder is that it does not prevent the shell output contrary to a simple file redirection. So you know in real-time (or quasi) what is going on unlike with a redirection.
Raziel wrote:...still, this command shouldn't lock up the shell, should it? :-)
Yes I agree
AmigaOne XE/G4
Hypex
Post by Hypex »
I can confirm here. It blanks my shell. How strange. :-)
It doesn't. Press Ctrl-C and then q, and you will get your prompt back.
Still, weird behaviour. I'll try experimenting a bit more ;-) here.
None of the Shell/con-handler/console group has changed since Update 2, so it must be something else causing it.
Raziel wrote: PIPE is in Devs:/DOSDrivers, but i assume there was a change in L:queue-handler which triggers this behaviour, no?
I don't think so. I just replaced the Update3 more command with the Update2 more command and that works. It looks like someone botched an update of the more command :-)
@nbache
ah, thank for that :-)
I gotta really try to dig out my old amiga knowledge ;-)
@xenic
damn, the nearest solution :-D
good catch, thanks...do you also know who is responsible for the more command?
...and ask him to fix it ;-)
Hihi, i like the update :-D
People are dying.
How dare you!
– Greta Thunberg
It seams to be a probablem with more and reading from a pipe as:
list >PIPE:mypipe
more <PIPE:mypipe
fails in a similar way, once you hit ctrl-c you et a warning that the file might be binary.
