FYI:Kernel will not work with an under OS4 formatted CF card
FYI:
Quote Tommysammy:
Same here, when i use CrossDosFilesystem together with cfide.device.kmod, i can format the cf card and use it on my WB but then doesn`t boot with linux kernel. When i format the cf card with Fat32 on my Win7 system, i can use it for Linux kernel but then the cf card doesn`t work on my WB.
Thanks to Tommysammy for the hint!
papaoskar
Re: FYI:Kernel will not work with an under OS4 formatted CF
Post by papaoskar »
Same here! Only I formatted the cf-card under Windows Vista it could be read by cfe.
Similar is the question of exchange data via a partition formated with NTSF on Amiga. Amiga can read, but not Linux.
papaoskar wrote:Same here! Only I formatted the cf-card under Windows Vista it could be read by cfe.
Thank you for your hints!
papaoskar
Post by papaoskar »
Has there been a solution for that problem in between?
