Font preferences (graphical glitch)
samo79
Post by samo79 »
This is the Font preferenced window as you open it:
But what happen if you try to resize the window as small as possible ?
See below:
Tested with Font 53.6 under AmigaOS 4.1 Final Edition (Theme: LightUp from Imagodespira)
Re: Font preferences (graphical glitch)
samo79 wrote:Tested with Font 53.6 under AmigaOS 4.1 Final Edition (Theme: LightUp from Imagodespira)
Does it also happen with the default theme? It doesn't here (same version of Font prefs).
samo79
Post by samo79 »
Tested and i have no problem with the standard theme .. i don't know what this theme changed to make this trashing effect, a bug still somewhere.
samo79
Post by samo79 »
@nbache
Same problem with the other (similar) themes of Imagodespira, can you open a report/ticket for this ?
samo79 wrote:@nbache
As far as I know, those themes are not a part of the OS. You should report it directly to the developer.
samo79
Post by samo79 »
I know that those themes aren't included, but problem here are not the theming for themself but the fact that graphics elements should not be corrupted while in certain case they are now
Another example taked from the same theme:
But still other case, for example try to install the SilveGreen theme (included in the OS 4.1 CD) and then resize a window in Orygn Web Browser (the Joerg version i mean)
To verify exactly what happen (and where) we might contact imagodespira asking what "specific" he used for that theme, and then report to our devs the exact component when problem reside ... well nothing special at the end, it's the classic job of the betatesters, annoying of course but necessary ..
If it happens only with those themes, the error is most likely there. If the author finds that it is caused by wrong documentation or a real bug in the system software, he can report that. It will definitely be a more precisely targeted report, as he knows what he has read/written/called.
samo79
Post by samo79 »
I sent him a private message, let's see ...
imagodespira
Post by imagodespira »
PM received. I will look at it. I only use standard stuff but I have an idea with background patterns winch where in earlier versions not correct and I also have a bug in the config for the bitmaps which is not a problem here but perhaps on your system.
I hope that it is one of the problems above ;)
Please can you write your configuration, computer and graphic card, os version‽
Edit. Ok final edition you have. Will look at it.
imagodespira
Really strange, it works fine here on my sam460. The base is the original theme only adjustments, so hard to find. But I see that I have to rework the theme on some parts , maybe I find something.
