I have bought the FE for my Classic A1200, my set up is the one you read in my signature.
started it with the floppy included, managed to finish the installation with no problems, on the first partition of the hd, DH0 with SFS/02 file system.
at reboot, no boot
a message appears:
software failure
ramlib
program failed (error #80000008)
wait for disk activity to finish
suspend reboot
but both suspend and reboot give no solution
tried to boot with no startup, same result
what could I do?
thanx
Final Edition on A1200 fails
Satiropan
PPA1200 (Poor Portable Amiga 1200): BPPC-160MB,
BVision-CGX4, HD 10GB, slim DVD R/W, Asus VW161D
display, 3COM Lan PC card, OS4.1FE
AmigaOne G3-SE 600MHz, 1GB, Radeon 9200 128DDR,
CS4281 sound card, RTL8029, SiI3114, OS 4.1.6 & OS4.1FE
http://www.oldfab.webs.com
Re: Final Edition on A1200 fails
found a partial solution:
FE already installed, again I boot from floppy/cdrom, choose to start workbench from cd, go to the HD startup-sequence, uncomment the first line which is about FastATA that I don't have
take cd out
warm reboot, the system actually boots from the HD, full fledged FE
but it has worked only once
take cd out
Satiropan
Did you choose the right settings during the install process?
FastATA should not be enabled by default (nor idefix etc.)
of course I have not enabled it since I have the plain A1200 ide interfacedavebraco wrote:Did you choose the right settings during the install process?
I have now seen that the boot workaround (booting FE floppy/cd then warm reset) that worked only one time now works again, and without uncommenting the first line in startup-sequence
anyway I will try a new installation with the fastata enabled, you never know...
Satiropan
I have started from scratch,
installed 3.9 from emergency floppy/cd on partition dh0, FFS since SFS is not seen
no problems at all
regular boot and the floppy icon is on WB, floppy is listed in early boot menu.
I start installation of 4.1FE, it's the same wheather I start from FE floppy/cd or just from cd using the 'install from 3.x' script
in the pre-install requester, the Amiga Technologies floppy is automatically enabled, stating that is so because the installer has not found the floppy (even if the machine booted from floppy/cd)
if I stop installing and do a warm reset, in the early startup menu, which is now the one from the FE kickstart, the floppy is not listed
same behaviour with a 4.0 installation
so I understand now that it is problem of kickstart modules, also for the ramlib problem I described earlier.
any ideas?
in the while I'll do some more tests, and finally I will try another motherboard, I have 3 of them
no problems at all
any ideas?
Satiropan
SOLVED
following what is inside the answer to question 1.9 in Classic_FAQ.pdf on the FE cdrom
I must say that if they had written on the instructions leaflet: PLEASE READ Classic_FAQ.pdf BEFORE INSTALLING, it would have saved me a lot of anxiety, lost sleep hours and headache!
BTW, boot partition must be inside the first 4GB of HD, and you have to see that the file system loaded in the RDB is the same as the one you will choose for the boot partition.
clicking on "Edit partitions and filesystems" in the partition window of media toolbox, you can add what file system you need in the RDB and as soon as you have loaded it, click on it and check that the dostype figure is as explained, 444F5307 for FFS and 53465300 for SFS/00 (SFS/02 is not listed in L directory, I don't know whether it has the same dostype as SFS/00).
save, choose the proper file system, proper maxtransfer and mask, save, reboot and install
then FE starts from HD with no problem, and as a bonus, the floppy is finally recognized and you see its icon on WB!
Satiropan
Glad you solved it!
I found in your signature that you're using a 3COM in the 1200 and a RTL8029 in the AOne. Does the 3COM works in the AOne? Otherwise, you could swap both cards.
the 3com is a pcmcia card, the rtl is pci, I don't have mediator on the a1200. the 3com chip on my AOne has been desoldered waiting to reballing it, but I have not yet decided to do it, so in the while I use the RTLdavebraco wrote:Glad you solved it!
Satiropan
Undestood. Enjoy the Final Edition on your miggies!
- DarrenHD
I'm glad my FAQ helped at least one usersatiropan wrote:SOLVED
Darren
