Hi guys,
It looks like there's a bug in the 4.1FE WBStartup preferences program (version 53.25). If you select any of the entries and click on Information, or double-click the entry, it opens the icon information window for the *icon* of the entry, and not of the entry itself. This means you can't change the tooltypes of the program you want to start when Workbench loads.
To edit these properties (DoNotWait, CX_Priority, CX_Popup etc.) you need to manually go to the program in question and change them that way. Not a big deal, but it would be much handier if the WBStartup prefs pointed at the right file first off.
Bug in WBStartup Prefs?
Re: Bug in WBStartup Prefs?
@Daedalus
I think that was reported in the topic "Bug in Prefs/WBStartup 53.25 (06.10.2014)" and a BZ created.
- Daedalus
Ah, cool, so there's a fix in the pipeline. Thanks, and sorry for the redundant thread!
