AmigaOS4.1 Update 3 USB Problems
This forum is for Pegasos II specific issues.
AmigaGTI
Post by AmigaGTI »
Hello.
I have a PegasosII with AmigaOS4.1 Update3. My USB2.0 Controller Cards with VIA VT6212 Chipset does not work. If i have Update 2 installed, the card would be work fine, but now there is nothing. USB sticks would be connected, but after one minute the stick could not be mounted and i got a read write error.
Help!
davebraco
Re: AmigaOS4.1 Update 3 USB Problems
Post by davebraco »
As a temporary work around, you should comment the line MODULE Kickstart/ehci.usbhcd in the sys:kickstart/kicklayout text file by adding ; in front of the line.
You will be able to use your usb controler card. Pay attention that it will "disable" the USB2 features.
More information could be found in these posts :
http://forum.hyperion-entertainment.biz ... hilit=ehci
http://forum.hyperion-entertainment.biz ... ehci#p3633
AmigaGTI
Post by AmigaGTI »
Thank you, i will try it.
btw, is there a chance that they would word with USB2.0 support in next time??
Hypex
Post by Hypex »
I have the same problem with a VIA USB card in my AmigaOne. Though I don't know the exact chipset I do know that is shares the exact same PCI ID as the onboard USB. Except the USB2 counterpart. So to me that is strange it isn't supported.
AmigaGTI
Post by AmigaGTI »
What i did not understood:
The PegasosII have a VIA Chipset. I think that the USB controller onBoard is a VIA Chip too. So why it does not work. I Have buy the cards with VIA Chipset at that reason.
Possibly none of the beta testers has that card in his machine, so nobody noticed that it worked with Update 2 but not with Update 3.
I'll raise a bug report and point the dev to this thread.
[edit]
Bug #7219.
In the meantime, would you like to try disabling EHCI and test if it still works in OHCI mode? You can do that by commenting out EHCI (with a ";" before the line MODULE Kickstart/ehci.usbhcd in Kickstart/kicklayout).
[/edit]
vulture
Post by vulture »
that's what happened with me as well, I replaced the via card with a nec one before update3 so, I never noticed the problem while testing, I was somewhat assured in my mind that it'd still work.
Peg2 2b5, G4@1.266ghz, 2gb RAM, Radeon 9200 128mb, Audigy 2 ZS, Nec USB 2.0, Sata sil3512
A1200 BPPC 603e@333mhz , 256mb RAM, BVision, Subway USB, Fasata MK1, 3com pcmcia ethernet
A1200 BPPC 603e@333mhz , 256mb RAM , Mediator 1200TX, Voodoo 3 3500, Radeon 9200 256mb, Spider USB2.0, Realtek 8029, Soundblaster Live!, Fastata MK3, 3com pcmcia ethernet
@AmigaGTI:
Are you still unable to use your USB card with Update 4?
If it still won't work with Update 4:
Can you please report the version numbers of:
kickstart/usbresource.library
kickstart/usbsys.device
devs/USB/fd/hid.usbfd
so that we can fix it before Update 5?
nubechecorre
Post by nubechecorre »
I have, also, problem with new usb stack (usb 2.0).. I am not able to use my D-Link Hub.. If i connect the keyboard and the mouse on the usb port directly no problems, but if I use the hub they don't work..
The mouse and the keyboard are like "dead" when plugged into hub.. There was no problem with update 2.. Sorry for posting this problem now but i had back my sam440ep only few days ago.. so i installed update 3 and then update 4..
This problem appeared just after update 3.. I thought that installing update 4 could fix the problem but it is still there..
http://www.os4games.it
Sam440ep mini-itx
Classic System:
Amiga 1200
Radeon 9250 128Mb VRam
Voodoo 3 3000 16Mb VRam
DVD-RW LG Dual Layer
SoundBlaster PCI 128
Cocolino Interface Elbox
AmigaOne White Mouse
Evillord68
Post by Evillord68 »
tonyw wrote:@AmigaGTI:
I will ask him, he is a moderator at www. a1k.org and i also.
If he still have this problem, he can send the card to me an i will test it in my Aone/PegII.
