I downloaded Mercurial (Python app) from OS4Depot but it won't install or work properly with OS4.1FE Python. When I cold boot from my OS4.1Update6 partition, Mercurial installs and works properly. When I copied the OS4.1 Update6 Mercurial installation in Python to Python in my OS4.1FE partition, Mercurial fails with this error:
** Mercurial Distributed SCM (version 1.9)
** Extensions loaded:
Traceback (most recent call last):
File "PROGDIR:hg", line 38, in <module>
mercurial.dispatch.run()
File "PYTHON:Lib/site-packages/mercurial/dispatch.py", line 27, in run
sys.exit(dispatch(request(sys.argv[1:])))
File "PYTHON:Lib/site-packages/mercurial/dispatch.py", line 64, in dispatch
return _runcatch(req)
File "PYTHON:Lib/site-packages/mercurial/dispatch.py", line 87, in _runcatch
return _dispatch(req)
File "PYTHON:Lib/site-packages/mercurial/dispatch.py", line 630, in _dispatch
return commands.help_(ui, 'shortlist')
File "PYTHON:Lib/site-packages/mercurial/commands.py", line 2588, in help_
textwidth = min(ui.termwidth(), 80) - 2
File "PYTHON:Lib/site-packages/mercurial/ui.py", line 498, in termwidth
return util.termwidth()
File "PYTHON:Lib/site-packages/mercurial/amiga.py", line 326, in termwidth
arri = fcntl.ioctl(fd, termios.TIOCGWINSZ, '\0' * 8)
AttributeError: 'module' object has no attribute 'TIOCGWINSZ'
It looks like something is missing or wrong in OS4.1FE Python.
Python problem
Python problem
Re: Python problem
@Xenic
Dunno if it anyhow related to your problem (and probably not), but just to collect all the problems with new python version : all "pygame" based apps from os4depot stop working with new python , and i already report it year or so ago to our BZ.
