I'm recieving an error code when attacing an card reader an HID device in a NEC card
The chip number is:
D720101GJ
0323EPA43
The HID device (USB competition pro
one header
Here's the USB log
I: [07:06:44] USB stack | | ==========
I: [07:06:44] USB stack | | USB System Software Task started
I: [07:06:44] USB stack | | Starting HCDs...
I: [07:06:44] USB stack | New Fkt | Fkt 0x6FF8DAA0 at level -1
I: [07:06:44] USB stack | New Fkt | Fkt 0x6FF8DB40 at level 0
I: [07:06:45] USB stack | New Fkt | Fkt 0x6FF8DBE0 at level -1
I: [07:06:45] USB stack | New Fkt | Fkt 0x6FF8DC80 at level 0
I: [07:06:45] USB stack | New Fkt | Fkt 0x6FF8DD20 at level -1
I: [07:06:45] USB stack | New Fkt | Fkt 0x6FF8DDC0 at level 0
I: [07:06:45] USB stack | | ...HCDs started.
I: [07:06:45] USB Fkt Init | Init Fkt | Fkt 0x6FF8DB40 is {Vendor: 0x0000, Product: 0x0000, Class: 09.00}
I: [07:06:45] USB Fkt Init | Init Fkt | Fkt 0x6FF8DC80 is {Vendor: 0x0000, Product: 0x0000, Class: 09.00}
I: [07:06:45] USB Fkt Init | Init Fkt | Fkt 0x6FF8DDC0 is {Vendor: 0x0000, Product: 0x0000, Class: 09.00}
I: [07:06:45] USB Fkt Init | Init Fkt | Fkt 0x6FF8DB40 initialized
I: [07:06:45] USB Fkt Init | Init Fkt | Fkt 0x6FF8DC80 initialized
I: [07:06:45] USB Fkt Init | Init Fkt | Fkt 0x6FF8DDC0 initialized
I: [07:06:45] hub.usbfd | HUB | Hub "Rear Roothub (ehci.usbhcd/0)" has TT thinktime of 8 full speed bittimes and protocol 0
I: [07:06:45] hub.usbfd | HUB | Hub "Rear Roothub (ohci.usbhcd/0)" has TT thinktime of 8 full speed bittimes and protocol 0
I: [07:06:45] hub.usbfd | HUB | Hub "Front Roothub (ohci.usbhcd/1)" has TT thinktime of 8 full speed bittimes and protocol 0
I: [07:06:45] hub.usbfd | HUB | All ports are empty
I: [07:06:45] EHCI Controller Task Unit 0 | EHCI | Device at port 2 is a lowspeed device. Giving up ownership.
I: [07:06:45] hub.usbfd | Sys_EndInitialAttachmentPhase | Initial USB Attachment Phase terminated
I: [07:06:45] hub.usbfd | HUB | Device found on port 2 of hub "Rear Roothub (ohci.usbhcd/0)".
I: [07:06:45] hub.usbfd | Hub port | Device at port 2 of hub "Rear Roothub (ohci.usbhcd/0)" is low-speed.
I: [07:06:45] USB stack | New Fkt | Fkt 0x6FDEC0B0 at level 1
I: [07:06:45] USB stack | New Fkt | HCD failed to add/create Fkt
W: [07:06:45] hub.usbfd | HUB | Retrying attachment on port 2 of hub "Rear Roothub (ohci.usbhcd/0)" (previous attempt failed with error -19)
I: [07:06:46] USB stack | New Fkt | Fkt 0x6FDEC0B0 at level 1
I: [07:06:46] USB stack | New Fkt | HCD failed to add/create Fkt
W: [07:06:46] hub.usbfd | HUB | Retrying attachment on port 2 of hub "Rear Roothub (ohci.usbhcd/0)" (previous attempt failed with error -19)
W: [07:06:46] hub.usbfd | HUB | Resetting hub port 2 and trying again
I: [07:06:46] hub.usbfd | Hub port | Device at port 2 of hub "Rear Roothub (ohci.usbhcd/0)" is low-speed.
I: [07:06:46] USB stack | New Fkt | Fkt 0x6FDEC5B0 at level 1
I: [07:06:46] USB stack | New Fkt | Fkt 0x6D2CA0C0 at level 1
I: [07:06:46] USB stack | New Fkt | Fkt 0x6d2ca200 at level 1
I: [07:06:46] USB stack | New Fkt | Fkt 0x6d2ca2a0 at level 1
I: [07:06:46] USB stack | New Fkt | Fkt 0x6d2ca3e0 at level 1
I: [07:06:46] USB stack | New Fkt | Fkt 0x6cecf850 at level 1
I: [07:06:47] USB stack | New Fkt | Fkt 0x6cecfe90 at level 1
I: [07:06:47] USB stack Process | | USB System Software Process started.
I: [07:06:47] USB stack | New Fkt | HCD failed to add/create Fkt
I: [07:06:47] USB stack Process | | Reading FD descriptors...
W: [07:06:47] hub.usbfd | HUB | Retrying attachment on port 2 of hub "Rear Roothub (ohci.usbhcd/0)" (previous attempt failed with error -19)
I: [07:06:47] USB stack Process | | ...FD infos read
I: [07:06:47] USB stack Process | | Starting HCDs...
I: [07:06:47] USB stack Process | | ...HCDs started.
I: [07:06:47] USB stack Process | Sys_EndInitialAttachmentPhase | Initial USB Attachment Phase terminated
I: [07:06:47] USB stack Process | | USB stack fullbooted
