I reported in the General AmigaOS forum that my compiles for large multi-file sources take over twice as long with OS4.1FE as with OS4.1u6. I have since discovered that the problem is with the current "make" command. If I replace the SDK:C/make command in the current public SDK with the "make" command from SDK v51.22, the compile speed is just as fast as the current make command is with OS4.1u6. All later make commands are just as slow as the current make with OS4.1u6. Something is wrong with the way the current make operates with OS4.1FE.
To summarize:
Current make command with OS4.1u6 operates normally.
Current make command with OS4.1FE take over twice as long to compile large multi-file sources.
Make command from SDK v51.22 operates normally and is as fast as current make with OS4.1u6.
Could we please get an updated make command that doesn't operate in slow motion??
SDK:C/make very slow with OS4.1FE (SOLVED)
- broadblues
Re: SDK:C/make very slow with OS4.1FE
Whilst I always work on latest beta when compiling I can't say I've noticed any deteriation in compiling speeds over time. However as my SDK is built incrementaly perhspa I'm still using an old make?xenic wrote:I reported in the General AmigaOS forum that my compiles for large multi-file sources take over twice as long with OS4.1FE as with OS4.1u6. I have since discovered that the problem is with the current "make" command. If I replace the SDK:C/make command in the current public SDK with the "make" command from SDK v51.22, the compile speed is just as fast as the current make command is with OS4.1u6. All later make commands are just as slow as the current make with OS4.1u6. Something is wrong with the way the current make operates with OS4.1FE.
To summarize:
What versions are you refereing too?
For example here I'm using:
9.AmigaOS4:> make --version
GNU Make 3.81
Copyright (C) 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
This program built for AmigaOS
9.AmigaOS4:> version appdir:make
make 53.1
9.AmigaOS4:> version appdir:make full
make 53.1 (22/01/2009)
9.AmigaOS4:> which make
Programing:SDK/C/make
9.AmigaOS4:>
There is no "make" command in OS4 or Final Edition. It's part of the SDK.
If you are experiencing different performance between Final Edition and OS4.1.6, then it is most likely due to the filesystems or partitions you are using.
What is different? What has changed?
Both boot partitions and the SDK are all on the same hard-disk. The FE partition is an SFS partition as recommended. The Update6 partition is an FFS partition. I switch boot partitions by changing the boot priorities with Media Toolbox and cold rebooting. I check that I'm using the correct kickstart by checking the version of dos.library. The SDK is located on an SFS2 partition. The sources being compiled are on another SFS2 partition.tonyw wrote: If you are experiencing different performance between Final Edition and OS4.1.6, then it is most likely due to the filesystems or partitions you are using.
The speed difference was confirmed in my "Slow compiling with OS4.1FE" topic in the General AmigaOS forum. The compile speed difference isn't perceptually apparent in small compiles. When you are compiling a large application containing hundreds of source files like Dopus5, the speed difference is very apparent. If you don't have large sources to test, here is a simple demonstration:
Create a dummy makefile in ram: with this content:
all: clean
clean:
rm -f *.o
rm -f *.o
rm -f *.o
rm -f *.o
rm -f *.o
rm -f *.o
rm -f *.o
rm -f *.o
rm -f *.o
rm -f *.o
If you perform the same procedure with OS4.1u6 the commands will scroll by in a flash (quickly).
If it's too much trouble to test with OS4.1u6 then comment out the "all:clean" and "clean:" lines with a semi-colon, save the file, set the "script" protection bit and then run or execute the file as a script. The commands will zoom by just as they do when the makefile is run make in OS4.1u6.
The make command from SDK v51.22 will run the above makefile as fast as when it's run as a script.
The slow version I'm complaining about is make version 53.1 from the latest public SDK. The old version that still works fast with OS4.1FE is make version 3.81rc2-4 from SDK v51.22. If you try the procedure I described to Tony you should be able to see how slow the current make command is with OS4.1FE.broadblues wrote: Whilst I always work on latest beta when compiling I can't say I've noticed any deteriation in compiling speeds over time. However as my SDK is built incrementaly perhspa I'm still using an old make?
If you would like to see how slow a huge application is with make 53.1 you can D/L a Dopus5 snapshot at https://sourceforge.net/p/dopus5allamig ... ree/trunk/ and compile it with "timer" from OS4Depot. Just CD to the trunk/source directory and enter "timer make os4". Then compile it the same way after cold booting with OS4.1u6. The times are dramatically different. You may need a couple of extra includes from https://sourceforge.net/p/dopus5allamig ... _includes/ if you don't already have them installed.
EDIT: If you try compiling Dopus5, clean the sources with "make os4 cleanall" to see how slow a simple clean is.
- broadblues
@Xenic
[Edit]you posted whilst I was replying makeing my comment redundant[/edit]
Looking at your example make file my immediate thought is check your setting for * as wild card in DOS prefs, between your two installations.
Depending exactly which version of make your are talking about the recent 'make' uses the amigaos shel by default and 'gmake' the abc-sh, the older ones maynot do so.
- broadblues
Interesting, I don;t have immediate access to your old make version but running a test make file I found something odd.
I set up a script
DEL
and a makefile
the call to set outputs the vars one of which is __Runtime this shows that all the deletes took
_RunTime 0.007573
but the makefile took
_RunTime 12.69713
very slow indeed!
But I'm not seeing this when I build software from CodeBench, or at least I'm not aware of it building seems very fast on my X1000 I'm testing on my SAM 440 here though.
So I tried typing ChangeTaskPri 2 and ran make again
_RunTime 3.080005
Better.
I tried assign T: work:T as make puts temporary scripts in T:
_RunTime 1.560468
I set up a script
DEL
.bra {
.ket }
.key FILE,QUIET/S
DELETE {FILE}
SET
all: clean
clean:
ECHO >ram:foo.o
DEL *.o QUIET
ECHO >ram:foo.o
DEL *.o QUIET
ECHO >ram:foo.o
DEL *.o QUIET
ECHO >ram:foo.o
DEL *.o QUIET
ECHO >ram:foo.o
DEL *.o QUIET
ECHO >ram:foo.o
DEL *.o QUIET
ECHO >ram:foo.o
DEL *.o QUIET
ECHO >ram:foo.o
DEL *.o QUIET
ECHO >ram:foo.o
DEL *.o QUIET
ECHO >ram:foo.o
DEL *.o QUIET
ECHO >ram:foo.o
_RunTime 0.007573
_RunTime 12.69713
very slow indeed!
_RunTime 3.080005
Better.
_RunTime 1.560468
I don't have time to do much at the moment, but I just tried changing priority for a "make" of a big job that I'm working on. I'm compiling on the X-1000 with a beta system (neither 4.1.6 nor FE).
Normal conditions, a full Make takes 1m 36s. When I changed the priority to 2, it took 1m 28s.
But in that state, the console would not run properly. Trying to type a file to the console, it would print for a second, pause whilst it filled its buffers, then print again, and so on.
I would need to install the SDK startup script (etc) on the FE partition to test it under that system. I won't be able to do that until tomorrow night.
- broadblues
I did a test on my X1000 on a moderatly sized project (8000 lines of code)
Normal priority -> 31 secs to build
ChangeTaskPri 2 -> 26 secs to build
So a slow down perhaps but not as dramatic as on my SAM.
The AmigaDOS setting for wildcards has no effect on the SDK's *nix based commands, regardless of what shell they are executed with. The command "rm -f *.o" will receive "*.o" as an argument and interpret it as a wildcard. That's the case even if it is run from an AmigaDOS script. Set AmigaDOS not recognize * as a wildcard. If you copy any file to ram: with a .o file extension, CD to ram and enter < rm -f *.o > in the shell then the file will be deleted.broadblues wrote:Looking at your example make file my immediate thought is check your setting for * as wild card in DOS prefs, between your two installations.
The make command (v53.1) is running at the same priority on OS4.1u6 and OS4.1FE so the priority isn't the issue. The project I'm building has over 500 source files (.c), 6 sub-makefiles, 23 sub-sub-makefiles and 50,000+ lines of code. The more source files and makefiles the more dramatic the compile time difference between OS4.1FE and OS4.1u6. If you combined all your source files into one, you probably wouldn't see any significant time difference. The time difference seems to depend on how many files make has to load and execute. Here are my times for compiling Dopus5 using the timer command (timer make):broadblues wrote:I did a test on my X1000 on a moderatly sized project (8000 lines of code)
Compile time with OS4.1 Update6: 225.2183 seconds
Compile time with OS4.1 FE: 541.3016 seconds
That's a big turnaround time when you're trying to debug & test. The point I'm trying to make is that something changed between OS4.1u6 and OS4.1FE that is causing make 53.1 to take much longer to compile huge applications. I'm just trying to help other programmers compile more effeciently and help the OS4 devs fix things that have apparently gone wrong. Because make v3.81rc2-4 is just as fast on OS4.1u6 and OS4.1FE, I'm convinced that make v53.1 needs some changes to make it work as well with OS4.1FE as with OS4.1u6.
Whether it's fixed or not will make little difference to me because I made some minor changes to the make v3.81rc2-4 sources and compiled it for my own use. I can compile just as fast on OS4.1FE with my modified make v3.81rc2-4 as I previously did with make v53.1 on OS4.1u6. I'll probably continue to use make v3.81rc2-4 since I can stop a compile with Ctrl-C whereas there doesn't seem to be any way to stop make 53.1 once it starts a compile. The only reason I'm reporting the make slowdown is to help others.
