(X)(L)ubuntu (MATE) 15.04
I updated my ubuntu MATE 14.10 to 15.04 today. I want to do some beta testing.
Important notes:
I got the following error message after the update:
systemd-logind[7220]: Failed to apply ACLs: Operation not supported
Therefore I had to compile a new kernel 3.19 with the following special options:
CONFIG_TMPFS_POSIX_ACL=y
CONFIG_TMPFS_XATTR=y
You need the new kernel 3.19 RC6-2 because of the ACL problems.
Additionally the system showed me the following error message:
Disk Drive / not ready yet or not available
I pressed 's' for skip and then I mounted it rw with
mount -o remount, rw /
I added rw to the boot arguments. This solved this problem.
Update instructions:
  1. Download the kernel 3.19 RC6-2: vmlinux-3.19.0-rc6-2-KVM-PR-AMIGA_one_X1000.tar.bz2
  2. Unpack the kernel package
  3. Copy the kernel vmlinux-3.19 to the CF card
  4. Copy the kernel modules directory to /lib/modules:
    sudo cp -R 3.19.0-rc6_A-EON_AMIGA_one_X1000_Nemo /lib/modules
  5. Reboot your AMIGA one X1000 and enter the firmware. If you have autoboot set up, press
    CTRL-C. If you have the latest menu-enabled firmware, press the F key to enter the firmware. In
    any case, you should end up on the firmware's command prompt which looks like this:
    CFE>
  6. Create a CFE boot entry for your new ubuntu MATE 15.04 for example:
    CFE> setenv -p MENU_3_LABEL "ubuntu MATE 15.04 Kernel 3.19"
    CFE> setenv -p MENU_3_COMMAND 'set pmu -astate=A4 ; setenv bootargs "root=/dev/sdb7 quiet ro splash rw" ; boot -elf -noints -fatfs cf0:vmlinux-3.19'
  7. To activate the new Boot Menu type menu and use the arrow keys to select and highlight 3: ubuntu MATE 15.04 Kernel 3.19 before the timer bar runs down.
  8. CTRL+ALT+F1 to change to the console login.
  9. Login as user
  10. Change your user to the root user with
    sudo su
  11. Stop X11 with
    service lightdm stop
  12. Update the package index of your old 14.10 system:
    apt-get update
  13. Upgrade your packages to the latest packages on your old 14.10 system:
    apt-get upgrade
  14. Remove those dependencies that were installed with applications and that are no longer used by anything else on the system:
    apt-get autoremove
  15. Remove .deb files for packages that are no longer installed on your system:
    apt-get autoclean
  16. Update your repositories to the new 15.04 repositories
    sed -i 's/utopic/vivid/g' /etc/apt/sources.list
    FYI: ubuntu MATE repository for splash screen, artwork, icons, and themes:
    /etc/apt/sources.list:
    deb http://ppa.launchpad.net/ubuntu-mate-dev/ppa/ubuntu vivid main
    If you don't have the ubuntu MATE PPA key, then you get it with:
    add-apt-repository ppa:ubuntu-mate-dev/ppa
  17. Update the package index of the new 15.04 system:
    apt-get update
  18. Upgrade your 14.10 system to version 15.04:
    apt-get dist-upgrade
  19. Reboot
  20. Login with your user
  21. Tidy up :D
    sudo apt-get autoremove
    and
    sudo apt-get autoclean
  22. Unfortunately, X11 doesn't work automatically. You need a xorg.conf.
  23. sudo su
  24. X -configure
  25. copy the xorg.conf.new to /etc/X11/xorg.conf:
    cp xorg.conf.new /etc/X11/xorg.conf
  26. Change the driver to radeon in the xorg.conf:
    Driver   "radeon"
  27. Reboot your AMIGA one X1000
  28. Login in your new ubuntu MATE 15.04 system.
  29. Download the unofficial Mesa: MesaLib-10.0.4-powerpc-unofficial.tar.bz2
  30. Extract it in your home folder
  31. Rename the original r600_dri.so to r600_dri.so.bak:
    sudo mv /usr/lib/powerpc-linux-gnu/dri/r600_dri.so /usr/lib/powerpc-linux-gnu/dri/r600_dri.so.bak
  32. Copy the patched r600_dri.so to /usr/lib/powerpc-linux-gnu/dri:
    sudo cp mesa-10.0.4/lib/dri/r600_dri.so /usr/lib/powerpc-linux-gnu/dri
  33. Rename the original LibGL.so.1.2.0 to LibGL.so.1.2.0.bak:
    sudo mv /usr/lib/powerpc-linux-gnu/mesa/libGL.so.1.2.0 /usr/lib/powerpc-linux-gnu/mesa/libGL.so.1.2.0.bak
  34. Copy the patched LibGL.so.1.2.0 to /usr/lib/powerpc-linux-gnu/mesa:
    sudo cp mesa-10.0.4/lib/LibGL.so.1.2.0 /usr/lib/powerpc-linux-gnu/mesa
  35. Copy the whole Mesa directory to /usr/local:
    sudo cp -R mesa-10.0.4 /usr/local
Unfortunately you need the environment variable LD_LIBRARY_PATH additionally.
export LD_LIBRARY_PATH=/usr/local/mesa-10.0.4/lib
You can test it with glxgears:
vblank_mode=0 glxgears
Srtest
Re: (X)(L)ubuntu (MATE) 15.04
Post by Srtest »
"systemd-logind[7220]: Failed to apply ACLs: Operation not supported"
That's exactly what I got when I tried to upgrade to the latest Mesa! And I thought what did I do wrong!
(on 14.10)
Mac-on-Linux/"PR" KVM works without any problems on ubuntu MATE 15.04 with kernel 3.19 RC7. :-)
I installed it with the following Debian package today: mol-kvm_0.9.73.0-ubuntu_powerpc.deb.
Post by zzd10h »
Thanks to your procedure, installation was without problem !
What is the window manager that you installed in your picture where STK is shown at the end of your first post ?
glxgears seems OK nevertheless STK is very slow to start and complains about r600 driver at startup (error shown in the upper left xterm in the following picture)
Edit : maybe that I made a mistake when I added the "export LD_LIBRARY_PATH..." ? I added it in my .bashrc and in my .profile (to be sure...)
Where do you add this export, please ?
zzd10h wrote:Thanks to your procedure, installation was without problem !
Fantasic! Thank you!
zzd10h wrote: What is the window manager that you installed in your picture where STK is shown at the end of your first post ?
This is a MATE desktop with the Marco window manager.
This will install the complete MATE desktop in Lubuntu:
sudo apt-get install mate-desktop-environment
This will install the complete MATE desktop including a few extras in Lubuntu:
sudo apt-get install mate-desktop-environment-extras
For the ubuntu MATE splash screen, artwork, icons, and themes you have to add the Ubuntu MATE PPA to the sources.list.
zzd10h wrote: glxgears seems OK nevertheless STK is very slow to start and complains about r600 driver at startup (error shown in the upper left xterm in the following picture)
Unfortunately you have to modify the file run_game.sh for STK to use the unofficial Mesa.
Edit run_game.sh:
LD_LIBRARY_PATH=.bin:/usr/local/mesa-10.0.4/lib: bin/supertuxkart
Have a lot of fun with testing the version 15.04. :-)
Post by zzd10h »
Yes, STK works now. Speed and sound are OK.
I will try to install LUbuntu and Mate-desktop this evening.
Thank you
Post by zzd10h »
I installed all the WM (X-K-L Ubuntu) and I was trying all the desktop environment.
Is someone tried Plasma desktop (maybe from KUbuntu) ?
Thank you
It looks very strange (psychedelic, slow and flashy). I don't know if it's normal :o
zzd10h wrote:Hi,
Thank you
Thank you for testing the KDE desktop. I think there are some colors wrong.
I tested QEMU 2.2 on ubuntu MATE 15.04 with the kernel 4.00 alpha 4 today. I booted my first Linux distribution that I ever bought. It's S.u.S.E Linux 5.0 from 1997. That's really impressed to work with my first Linux distribution and with the modern ubuntu MATE 15.04 PowerPC together at the same time.
It's nice to see the old S.u.S.E FVWM 2 and the old Netscape browsers.
Have a nice weekend!
