Anyone else having issues when adding stuff to WBStartup in prefs.
Everytime I add something to it and edit it. Upon saving, it changes all items in list to from SYS: to partition name and then creates a .info.info file to every item in the WBStartup.
So it dumps the correct info file and instead uses .info.info. If you reboot with it like this, nothing in WBStartup gets loaded and it screws up workbench.
I tried manually copying over the files from disc, but it still uses the .info.info. I had to delete all .info.info and then copy files across, then it started working.
This issue is reproducable everytime.
WBStartup issue
- Christopher Follett
- AmigaKit
WBStartup issue
__________________
New Products
Re: WBStartup issue
I think you'll find this is fixed in the latest prefs editor which hasn't yet been released as an update.
Simon
Simon
- AmigaKit
Re: WBStartup issue
Thanks Simon, thought it was me until it happened 3 times in a row.Rigo wrote:I think you'll find this is fixed in the latest prefs editor which hasn't yet been released as an update.
Simon
__________________
New Products
