RAWBInfo "write protected" state
This is a minor problem but I figured it should be reported.
When calling up Information on a write-protected volume, RAWBInfo is showing "state: write protected", which is correct. However, it is showing it as a clickable button the same as a soft write-protected volume. I'm not sure if it is possible to tell the difference between a physically write-protected volume and one which has been soft-locked through the filesystem, but if it is, it shouldn't be showing a button to unprotect it.
Upon clicking the button I get a "volume xxx is write protected" message (I know!) followed by the requester to get the password to soft-unlock it. Neither of these make sense on a physically protected disk.
In case this is filesystem dependant, I ran these tests on a CD. (CDFileSystem 53.4 - from Final Edition)
Spektro
Re: RAWBInfo "write protected" state
Post by Spektro »
Thanks for your report! I've filed a bug report so that developers can fix the problem.
- Janne Peräaho
Creols
Post by Creols »
Today, there is another RAWBInfo sent to us for testing.
It's to me as "write" state!
AmigaOne XE, µA1, Sam 440ep, Sam Flex 800 MHz, Sam 460 ex, X1000 and more...
Cool, that was quick!
