ATI Drivers In Kernel?
mechanic
Post by mechanic »
After a bout of Male Mentelpause I have lost my config file and kernel I was using on X1000. I have re-installed Mint 11 using the 3.5.7 kernel and need to build another custom kernel. I want to try 3.14.2 first but have forgotten which graphics firmware needs to be built into the kernel for boot and run.
I have a HD6850 and know the 4 BARTS and the BTC firmware need to be compiled in but there is also 1 or 2 more (I think) necessary to prevent the long wait at startup at .....returning from PROMint.
Any idea?
Re: ATI Drivers In Kernel?
mechanic wrote:ATI Drivers In Kernel?
Any idea?
3.14 is an old kernel. You could use the 3.17 or 3.18 kernel. The Radeon drivers are compiled in these kernels. In these packages are the kernel configs too. In these configs you can see which firmware files are required for your HD6850 (BARTS).
Kernel downloads: supertuxkart-amiga.de
daz
Post by daz »
Boot with the kernel you want to rebuild and enter the following in a terminal:
zcat /proc/config.gz >cur_config
Then load (or rename to .config) the file cur_config.
Any idea?
For that card the files you need are:
BARTS_mc.bin
BARTS_me.bin
BARTS_pfp.bin
BTC_rlc.bin (This one is the common interrupt driver for Barts Turks and Caicos cards)
and depending on which kernel you intend to use you may also need:
BARTS_smc.bin
Note these names are case sensitive!
Regards
Darren
mechanic
Post by mechanic »
Thanks Darren,
The problem is I don't have the 3.10 kernel to extract from. Pfft! Gone.
I'm able to build the other kernels, and they work, but they all take a long time waiting at "returning from prom_int" . So I'm either missing something or have forgotten something, or perhaps maybe it's the compiler(???).
I'll keep at it.
mechanic
Post by mechanic »
Problem solved.
All that is needed is to rip half the stuff out of the kernel. :twisted:
mechanic wrote:Problem solved.
I could host your small kernels if you like. ;-) I think there are some people who are interested in small kernels.
mechanic
Post by mechanic »
The problem with that is my kernel is only for the extra equipment in my computer. If they have a different video card, or two video cards, or are using a different sound card then they would be in trouble.
What is really needed is to get more people building kernels. They don't have to be experts, and as long as they don't replace the running kernel & modules with something of the same name.....then it's okay to screw up a new kernel, trash it, and try again.
I think you are doing a wonderful job with kernel development and for you to get side tracked with building custom kernels, or trying to answer questions about them would be a shame.
I just wish people would be less afraid of crashing a computer in the persuit of knowledge.
It ain't like crashing a car. :cry:
mechanic
Post by mechanic »
Just for your amusement I attached my 3.14.2 Makefile from the 3.14.2 source code firmware directory. You might be interested in the Make modules_install part near the top.
Hidden Text - Click to Show :
# kbuild file for firmware/
# Create $(fwabs) from $(CONFIG_EXTRA_FIRMWARE_DIR) -- if it doesn't have a
# leading /, it's relative to $(srctree).
fwdir := $(subst ",,$(CONFIG_EXTRA_FIRMWARE_DIR))
fwabs := $(addprefix $(srctree)/,$(filter-out /%,$(fwdir)))$(filter /%,$(fwdir))
fw-external-y := $(subst ",,$(CONFIG_EXTRA_FIRMWARE))
# There are three cases to care about:
# 1. Building kernel with CONFIG_FIRMWARE_IN_KERNEL=y -- $(fw-shipped-y) should
# include the firmware files to include, according to .config
# 2. 'make modules_install', which will install firmware for modules, and
# _also_ for the in-kernel drivers when CONFIG_FIRMWARE_IN_KERNEL=n
# 3. 'make firmware_install', which installs all firmware, unconditionally.
# For the former two cases we want $(fw-shipped-y) and $(fw-shipped-m) to be
# accurate. In the latter case it doesn't matter -- it'll use $(fw-shipped-all).
# But be aware that the config file might not be included at all.
ifdef CONFIG_ACENIC_OMIT_TIGON_I
acenic-objs := acenic/tg2.bin
fw-shipped- += acenic/tg1.bin
else
acenic-objs := acenic/tg1.bin acenic/tg2.bin
endif
fw-shipped-$(CONFIG_ACENIC) += $(acenic-objs)
#fw-shipped-$(CONFIG_ADAPTEC_STARFIRE) += adaptec/starfire_rx.bin \
# adaptec/starfire_tx.bin
#fw-shipped-$(CONFIG_ATARI_DSP56K) += dsp56k/bootstrap.bin
#fw-shipped-$(CONFIG_ATM_AMBASSADOR) += atmsar11.fw
#fw-shipped-$(CONFIG_BNX2X) += bnx2x/bnx2x-e1-6.2.9.0.fw \
# bnx2x/bnx2x-e1h-6.2.9.0.fw \
# bnx2x/bnx2x-e2-6.2.9.0.fw
#fw-shipped-$(CONFIG_BNX2) += bnx2/bnx2-mips-09-6.2.1a.fw \
# bnx2/bnx2-rv2p-09-6.0.17.fw \
# bnx2/bnx2-rv2p-09ax-6.0.17.fw \
# bnx2/bnx2-mips-06-6.2.1.fw \
# bnx2/bnx2-rv2p-06-6.0.15.fw
#fw-shipped-$(CONFIG_CASSINI) += sun/cassini.bin
#fw-shipped-$(CONFIG_CHELSIO_T3) += cxgb3/t3b_psram-1.1.0.bin \
# cxgb3/t3c_psram-1.1.0.bin \
# cxgb3/ael2005_opt_edc.bin \
# cxgb3/ael2005_twx_edc.bin \
# cxgb3/ael2020_twx_edc.bin
#fw-shipped-$(CONFIG_DRM_MGA) += matrox/g200_warp.fw matrox/g400_warp.fw
#fw-shipped-$(CONFIG_DRM_R128) += r128/r128_cce.bin
#fw-shipped-$(CONFIG_DRM_RADEON) += radeon/R100_cp.bin radeon/R200_cp.bin \
# radeon/R300_cp.bin radeon/R420_cp.bin \
# radeon/RS690_cp.bin radeon/RS600_cp.bin \
# radeon/R520_cp.bin \
# radeon/R600_pfp.bin radeon/R600_me.bin \
# radeon/RV610_pfp.bin radeon/RV610_me.bin \
# radeon/RV630_pfp.bin radeon/RV630_me.bin \
# radeon/RV620_pfp.bin radeon/RV620_me.bin \
# radeon/RV635_pfp.bin radeon/RV635_me.bin \
# radeon/RV670_pfp.bin radeon/RV670_me.bin \
# radeon/RS780_pfp.bin radeon/RS780_me.bin \
# radeon/RV770_pfp.bin radeon/RV770_me.bin \
# radeon/RV730_pfp.bin radeon/RV730_me.bin \
# radeon/RV710_pfp.bin radeon/RV710_me.bin
#fw-shipped-$(CONFIG_DVB_AV7110) += av7110/bootcode.bin
#fw-shipped-$(CONFIG_DVB_TTUSB_BUDGET) += ttusb-budget/dspbootcode.bin
#fw-shipped-$(CONFIG_E100) += e100/d101m_ucode.bin e100/d101s_ucode.bin \
# e100/d102e_ucode.bin
#fw-shipped-$(CONFIG_MYRI_SBUS) += myricom/lanai.bin
#fw-shipped-$(CONFIG_PCMCIA_PCNET) += cis/LA-PCM.cis cis/PCMLM28.cis \
# cis/DP83903.cis cis/NE2K.cis \
# cis/tamarack.cis cis/PE-200.cis \
# cis/PE520.cis
#fw-shipped-$(CONFIG_PCMCIA_3C589) += cis/3CXEM556.cis
#fw-shipped-$(CONFIG_PCMCIA_3C574) += cis/3CCFEM556.cis
#fw-shipped-$(CONFIG_SERIAL_8250_CS) += cis/MT5634ZLX.cis cis/RS-COM-2P.cis \
# cis/COMpad2.cis cis/COMpad4.cis \
# cis/SW_555_SER.cis cis/SW_7xx_SER.cis \
# cis/SW_8xx_SER.cis
#fw-shipped-$(CONFIG_PCMCIA_SMC91C92) += ositech/Xilinx7OD.bin
#fw-shipped-$(CONFIG_SCSI_ADVANSYS) += advansys/mcode.bin advansys/38C1600.bin \
# advansys/3550.bin advansys/38C0800.bin
#fw-shipped-$(CONFIG_SCSI_QLOGIC_1280) += qlogic/1040.bin qlogic/1280.bin \
# qlogic/12160.bin
#fw-shipped-$(CONFIG_SCSI_QLOGICPTI) += qlogic/isp1000.bin
#fw-shipped-$(CONFIG_INFINIBAND_QIB) += qlogic/sd7220.fw
#fw-shipped-$(CONFIG_SND_KORG1212) += korg/k1212.dsp
#fw-shipped-$(CONFIG_SND_MAESTRO3) += ess/maestro3_assp_kernel.fw \
# ess/maestro3_assp_minisrc.fw
fw-shipped-$(CONFIG_SND_SB16_CSP) += sb16/mulaw_main.csp sb16/alaw_main.csp \
sb16/ima_adpcm_init.csp \
sb16/ima_adpcm_playback.csp \
sb16/ima_adpcm_capture.csp
#fw-shipped-$(CONFIG_SND_YMFPCI) += yamaha/ds1_ctrl.fw yamaha/ds1_dsp.fw \
# yamaha/ds1e_ctrl.fw
#fw-shipped-$(CONFIG_SND_WAVEFRONT) += yamaha/yss225_registers.bin
#fw-shipped-$(CONFIG_TEHUTI) += tehuti/bdx.bin
#fw-shipped-$(CONFIG_TIGON3) += tigon/tg3.bin tigon/tg3_tso.bin \
# tigon/tg3_tso5.bin
fw-shipped-$(CONFIG_TYPHOON) += 3com/typhoon.bin
#fw-shipped-$(CONFIG_USB_EMI26) += emi26/loader.fw emi26/firmware.fw \
# emi26/bitstream.fw
#fw-shipped-$(CONFIG_USB_EMI62) += emi62/loader.fw emi62/bitstream.fw \
# emi62/spdif.fw emi62/midi.fw
#fw-shipped-$(CONFIG_USB_KAWETH) += kaweth/new_code.bin kaweth/trigger_code.bin \
# kaweth/new_code_fix.bin \
# kaweth/trigger_code_fix.bin
ifdef CONFIG_FIRMWARE_IN_KERNEL
fw-shipped-$(CONFIG_USB_SERIAL_KEYSPAN_MPR) += keyspan/mpr.fw
fw-shipped-$(CONFIG_USB_SERIAL_KEYSPAN_USA18X) += keyspan/usa18x.fw
fw-shipped-$(CONFIG_USB_SERIAL_KEYSPAN_USA19) += keyspan/usa19.fw
fw-shipped-$(CONFIG_USB_SERIAL_KEYSPAN_USA19QI) += keyspan/usa19qi.fw
fw-shipped-$(CONFIG_USB_SERIAL_KEYSPAN_USA19QW) += keyspan/usa19qw.fw
fw-shipped-$(CONFIG_USB_SERIAL_KEYSPAN_USA19W) += keyspan/usa19w.fw
fw-shipped-$(CONFIG_USB_SERIAL_KEYSPAN_USA28) += keyspan/usa28.fw
fw-shipped-$(CONFIG_USB_SERIAL_KEYSPAN_USA28XA) += keyspan/usa28xa.fw
fw-shipped-$(CONFIG_USB_SERIAL_KEYSPAN_USA28XB) += keyspan/usa28xb.fw
fw-shipped-$(CONFIG_USB_SERIAL_KEYSPAN_USA28X) += keyspan/usa28x.fw
fw-shipped-$(CONFIG_USB_SERIAL_KEYSPAN_USA49W) += keyspan/usa49w.fw
fw-shipped-$(CONFIG_USB_SERIAL_KEYSPAN_USA49WLC) += keyspan/usa49wlc.fw
else
fw-shipped- += keyspan/mpr.fw keyspan/usa18x.fw keyspan/usa19.fw \
keyspan/usa19qi.fw keyspan/usa19qw.fw keyspan/usa19w.fw \
keyspan/usa28.fw keyspan/usa28xa.fw keyspan/usa28xb.fw \
keyspan/usa28x.fw keyspan/usa49w.fw keyspan/usa49wlc.fw
endif
fw-shipped-$(CONFIG_USB_SERIAL_TI) += ti_3410.fw ti_5052.fw \
mts_cdma.fw mts_gsm.fw mts_edge.fw
fw-shipped-$(CONFIG_USB_SERIAL_EDGEPORT) += edgeport/boot.fw edgeport/boot2.fw \
edgeport/down.fw edgeport/down2.fw
fw-shipped-$(CONFIG_USB_SERIAL_EDGEPORT_TI) += edgeport/down3.bin
fw-shipped-$(CONFIG_USB_SERIAL_WHITEHEAT) += whiteheat_loader.fw whiteheat.fw \
# whiteheat_loader_debug.fw
fw-shipped-$(CONFIG_USB_SERIAL_KEYSPAN_PDA) += keyspan_pda/keyspan_pda.fw
fw-shipped-$(CONFIG_USB_SERIAL_XIRCOM) += keyspan_pda/xircom_pgs.fw
fw-shipped-$(CONFIG_USB_VICAM) += vicam/firmware.fw
fw-shipped-$(CONFIG_VIDEO_CPIA2) += cpia2/stv0672_vp4.bin
fw-shipped-$(CONFIG_YAM) += yam/1200.bin yam/9600.bin
fw-shipped-all := $(fw-shipped-y) $(fw-shipped-m) $(fw-shipped-)
# Directories which we _might_ need to create, so we have a rule for them.
firmware-dirs := $(sort $(addprefix $(objtree)/$(obj)/,$(dir $(fw-external-y) $(fw-shipped-all))))
quiet_cmd_mkdir = MKDIR $(patsubst $(objtree)/%,%,$@)
cmd_mkdir = mkdir -p $@
quiet_cmd_ihex = IHEX $@
cmd_ihex = $(OBJCOPY) -Iihex -Obinary $< $@
quiet_cmd_ihex2fw = IHEX2FW $@
cmd_ihex2fw = $(objtree)/$(obj)/ihex2fw $< $@
quiet_cmd_h16tofw = H16TOFW $@
cmd_h16tofw = $(objtree)/$(obj)/ihex2fw -w $< $@
quiet_cmd_fwbin = MK_FW $@
cmd_fwbin = FWNAME="$(patsubst firmware/%.gen.S,%,$@)"; \
FWSTR="$(subst /,_,$(subst .,_,$(subst -,_,$(patsubst \
firmware/%.gen.S,%,$@))))"; \
ASM_WORD=$(if $(CONFIG_64BIT),.quad,.long); \
ASM_ALIGN=$(if $(CONFIG_64BIT),3,2); \
PROGBITS=$(if $(CONFIG_ARM),%,@)progbits; \
echo "/* Generated by firmware/Makefile */" > $@;\
echo " .section .rodata" >>$@;\
echo " .p2align $${ASM_ALIGN}" >>$@;\
echo "_fw_$${FWSTR}_bin:" >>$@;\
echo " .incbin \"$(2)\"" >>$@;\
echo "_fw_end:" >>$@;\
echo " .section .rodata.str,\"aMS\",$${PROGBITS},1" >>$@;\
echo "_fw_$${FWSTR}_name:" >>$@;\
echo " .string \"$$FWNAME\"" >>$@;\
echo " .section .builtin_fw,\"a\",$${PROGBITS}" >>$@;\
echo " $${ASM_WORD} _fw_$${FWSTR}_name" >>$@;\
echo " $${ASM_WORD} _fw_$${FWSTR}_bin" >>$@;\
echo " $${ASM_WORD} _fw_end - _fw_$${FWSTR}_bin" >>$@;
# One of these files will change, or come into existence, whenever
# the configuration changes between 32-bit and 64-bit. The .S files
# need to change when that happens.
wordsize_deps := $(wildcard include/config/64bit.h include/config/32bit.h \
include/config/ppc32.h include/config/ppc64.h \
include/config/superh32.h include/config/superh64.h \
include/config/x86_32.h include/config/x86_64.h)
# Workaround for make < 3.81, where .SECONDEXPANSION doesn't work.
# It'll end up depending on these targets, so make them a PHONY rule which
# depends on _all_ the directories in $(firmware-dirs), and it'll work out OK.
PHONY += $(objtree)/$$(%) $(objtree)/$(obj)/$$(%)
$(objtree)/$$(%) $(objtree)/$(obj)/$$(%): $(firmware-dirs)
@true
# For the $$(dir %) trick, where we need % to be expanded first.
.SECONDEXPANSION:
$(patsubst %,$(obj)/%.gen.S, $(fw-shipped-y)): %: $(wordsize_deps) \
| $(objtree)/$$(dir %)
$(call cmd,fwbin,$(patsubst %.gen.S,%,$@))
$(patsubst %,$(obj)/%.gen.S, $(fw-external-y)): %: $(wordsize_deps) \
include/config/extra/firmware/dir.h | $(objtree)/$$(dir %)
$(call cmd,fwbin,$(fwabs)/$(patsubst $(obj)/%.gen.S,%,$@))
# The .o files depend on the binaries directly; the .S files don't.
$(patsubst %,$(obj)/%.gen.o, $(fw-shipped-y)): %.gen.o: %
$(patsubst %,$(obj)/%.gen.o, $(fw-external-y)): $(obj)/%.gen.o: $(fwdir)/%
# .ihex is used just as a simple way to hold binary files in a source tree
# where binaries are frowned upon. They are directly converted with objcopy.
$(obj)/%: $(obj)/%.ihex | $(objtree)/$(obj)/$$(dir %)
$(call cmd,ihex)
# Don't depend on ihex2fw if we're installing and it already exists.
# Putting it after | in the dependencies doesn't seem sufficient when
# we're installing after a cross-compile, because ihex2fw has dependencies
# on stuff like /usr/lib/gcc/ppc64-redhat-linux/4.3.0/include/stddef.h and
# thus wants to be rebuilt. Which it can't be, if the prebuilt kernel tree
# is exported read-only for someone to run 'make install'.
ifeq ($(INSTALL):$(wildcard $(obj)/ihex2fw),install:$(obj)/ihex2fw)
ihex2fw_dep :=
else
ihex2fw_dep := $(obj)/ihex2fw
endif
# .HEX is also Intel HEX, but where the offset and length in each record
# is actually meaningful, because the firmware has to be loaded in a certain
# order rather than as a single binary blob. Thus, we convert them into our
# more compact binary representation of ihex records (<linux/ihex.h>)
$(obj)/%.fw: $(obj)/%.HEX $(ihex2fw_dep) | $(objtree)/$(obj)/$$(dir %)
$(call cmd,ihex2fw)
# .H16 is our own modified form of Intel HEX, with 16-bit length for records.
$(obj)/%.fw: $(obj)/%.H16 $(ihex2fw_dep) | $(objtree)/$(obj)/$$(dir %)
$(call cmd,h16tofw)
$(firmware-dirs):
$(call cmd,mkdir)
obj-y += $(patsubst %,%.gen.o, $(fw-external-y))
obj-$(CONFIG_FIRMWARE_IN_KERNEL) += $(patsubst %,%.gen.o, $(fw-shipped-y))
# Remove .S files and binaries created from ihex
# (during 'make clean' .config isn't included so they're all in $(fw-shipped-))
targets := $(fw-shipped-) $(patsubst $(obj)/%,%, \
$(shell find $(obj) -name \*.gen.S 2>/dev/null))
# Without this, built-in.o won't be created when it's empty, and the
# final vmlinux link will fail.
obj-n := dummy
hostprogs-y := ihex2fw
Notice all the # marks?
I'm not sure how much more can be safely removed.
It's all fun ;)
I would post my config file but it's 9k too big for this forum,,,,, besides, it would probably give you a heart attack. :shock:
mechanic wrote: What is really needed is to get more people building kernels.
You're right.
mechanic wrote: I think you are doing a wonderful job with kernel development and for you to get side tracked with building custom kernels, or trying to answer questions about them would be a shame.
Thank you! My pleasure! But there are a lot of people in the background, who work day by day for the Linux support for all A-EON AMIGA ones. ;-) Thank you to Alex Perez, Pat Wall, Darren Stevens, and Trevor Dickinson for the great work in the background. :-)
