Hello!
I've very surprised to see that this update does not include an updated con-handler and console.device? Is this just an error or has something happened to decide it is not to be included?
Regards,
Joachim Birging
Update 3 - No new con-handler?
Re: Update 3 - No new con-handler?
I did notice too after running CLI that the standard shell still hasn't got a scroll bar. Back to 68K for me!
- javierdlr
patience. will come when it's done, well betatested
AFAIK it's been tested and used for quite some time. I can quote a core developer on that...javierdlr wrote:patience. will come when it's done, well betatested
I've learnt it been held but no other reason than "sorry, boss said nope" was given. To say the least I am very disappointed.
The update was focused on bug fixes. The new console is a brand new feature and will be included in the next major release.zerohero wrote:I've very surprised to see that this update does not include an updated con-handler and console.device? Is this just an error or has something happened to decide it is not to be included?
Yes. charge another €100 (would make it €400 for me, if I decide to buy it) for an updated shell. Sorry about the cynical view, but this was a big let down to me.ssolie wrote:The update was focused on bug fixes. The new console is a brand new feature and will be included in the next major release.
EDIT:
And how can USB v2 be a bug fix while console.device and con-handler is not? That just doesn't make sense...
Not sure, because both have been in development for years and I think were originally planned for 4.0.zerohero wrote:And how can USB v2 be a bug fix while console.device and con-handler is not? That just doesn't make sense...
It was not planned to release the new con-handler with update 3. Maybe the new con-handler is not fully finished and need to be deeply tested...
More over USB2 seems to be more urgent than a new con-handler to basic end user.
Zero Hero, I don't think the next major update will only contain an updated con-handler.
Not finished or tested yet? I don't believe that.davebraco wrote:It was not planned to release the new con-handler with update 3. Maybe the new con-handler is not fully finished and need to be deeply tested...
Sure, the next major update will contain a lot more than an updated shell, but how many times must I buy the same OS before I get a usable shell? It's been 3 times already and don't tell me the shell is usable. Try compiling anything that throws a few errors and warnings then see how you solve it.
