Wrong icon position during iconification
samo79
Post by samo79 »
As some noted already many internal programs have a wrong allineament when iconified, this thread try to list all the involved programs that are affected by this .. i hoped to see them fixed in final update (as that are an old issue) but sadly all still the same
An example: http://postimg.org/image/6bqb8cj7l/
This is the list of the involved utility:
Sys:Prefs:
AmigaInput
Notifications
WBStartup
Sys:System:
Media ToolBox
Shell
FormatCDRW
Sys:Utilities
IconEdit
LogViewer
ShowConfig
Exchange (in "Commodities" directory)
Still to say that we have also some utilitied without any iconification gadget, for example the "ScreenBlanker" in SYS:Prefs, would be cool to add one on them ;)
Re: Wrong icon position during iconification
What is wrong?
samo79
Post by samo79 »
@tonyw
What is wrong?
Did you see the grab above ?
The "AmigaInput" icon should be placed just below the "NO NAME" icon, instead it will be iconified elsewhere
salass00
Post by salass00 »
tonyw wrote:What is wrong?
The icon's do_CurrentX and do_CurrentY fields are not set to NO_ICON_POSITION as they should be, so instead of iconifying to the first free position on the desktop it will iconify to where the program icon has been snapshotted.
When I iconify the console, its AppIcon appears in the "next place" on the WB, but that may be because it can't get to where it wants to.
I'll write a BZ to remind me to add it to the IWorkbench->AddAppIcon() call.
BZ #9105.
samo79
Post by samo79 »
tonyw wrote:When I iconify the console, its AppIcon appears in the "next place" on the WB, but that may be because it can't get to where it wants to.
BZ #9105.
Tony as you are here please can you open a specific ticket for every single program i've listed in this thread ?
I fear they will forgotten (as very often may happen with a bugreport)
So excluding your shell remain the fix those:
AmigaInput
Notifications
WBStartup
Media ToolBox
IconEdit
LogViewer
ShowConfig
Thanks ;)
salass00
Post by salass00 »
tonyw wrote: I'll write a BZ to remind me to add it to the IWorkbench->AddAppIcon() call.
That's not a good idea as some programs allow the app icon to be snappshotted into a specific place on the WB screen like LimpidClock for instance. This would be impossible if AddAppIcon() always forced the position to NO_ICON_POSITION.
Rather the programs in question should be fixed or possibly window.class.
salass00 wrote:
tonyw wrote:I'll write a BZ to remind me to add it to the IWorkbench->AddAppIcon() call.
Rather the programs in question should be fixed [...]
Tony's BZ is for (his own) console.
samo79
Post by samo79 »
@betatester
Anyone availible for opening a separate ticket for each programs listed above ?
salass00
Post by salass00 »
nbache wrote:Tony's BZ is for (his own) console.
I just read the BZ entry and as you say it is filed correctly.
