Minor AmiUpdate bug - mis-notification
saimo
Post by saimo »
AmiUpdate has had this minor bug since a long time (but I never got around to report it before :oops:), so it has not been introduced recently, and is not relative to AOS 4.1. FE.
When I start it, I get this:
This is a mis-detection as I don't have the Rollback drawer at all.
MichaelMerkel
Re: Minor AmiUpdate bug - mis-notification
Post by MichaelMerkel »
no rollback drawer?! but why?
i guess that in that case there is a default drawer used in the progdir:? maybe you can check with snoopy where it is accessed and convert it?
regards...
michael
Michael Merkel :lol:
saimo
Post by saimo »
The Rollback drawer is precisely the one that should be in PROGDIR: (and isn't there).
This is what my AmiUpdate drawer contains:
Directory "OS:System/AmiUpdate" on Sunday 18-Jan-15
AmiUpdate                    317472 ----rwed 27-Dec-14 01:57:36
AmiUpdate.info                 8661 ----rw-d Wednesday 00:10:14
IgnoreList                      923 ----rwed Wednesday 02:31:04
Images                          Dir ----rwed Yesterday 00:38:45
Libs                            Dir ----rwed Wednesday 23:52:57
MapList                         112 ----rwed 11-Jan-14 22:20:48
Modules                         Dir ----rwed Wednesday 23:52:57
SiteList                         35 ----rwed 14-Oct-12 09:19:50
MichaelMerkel
but where is it?
please call rollback from the menu and try to figure.
does it list anything? if you can use snoopy to check where it is placed.
regards...
michael
saimo
Post by saimo »
I don't have the Rollback drawer because I don't want it - I don't use the Rollback functionality. But my preferences are irrelevant: the point here is that when there is no Rollback drawer AmiUpdate throws that message, which is instead related to another kind of error.
At any rate, you are probably better off reporting the issue here: http://amiupdate.codebench.co.uk/bugtracker/bughome.php
saimo
Post by saimo »
Thanks, I didn't know there was a separate place. Done.
