AOS 4.1 FE bug - wrong file attrib. color in Workbench prefs
saimo
Post by saimo »
I have noticed a few minor defects in AOS 4.1 FE that I haven't seen mentioned elsewhere, so I have decided to report them. Eventually I went for separate threads to avoid confusion.
If the problem described below is already discussed elsewhere, please feel free to just point me to the right place. Thanks.
My system:
* A1 XE G4
* 512 MB RAM
* Radeon 9000 with 64 MB RAM
* SoundBlaster Live!
* IDE HD on a1ide.device (normally turned off at the beginning of the startup-sequence)
* SATA SDD on Sil5312ide.device
* all partitions formatted with SFS/00
This is a very minor bug in the Workbench preferences program. What happens is that when the Text mode tab is selected first, the file attributes color does not reflect the actual color chosen (at least when it's custom).
This is what is displayed when I open the tab for the first time:
Then, it's enough to click the Options tab and then return to the Appearance tab to get the correct result:
MichaelMerkel
Re: AOS 4.1 FE bug - wrong file attrib. color in Workbench p
Post by MichaelMerkel »
confirmed from my side.
the color field is not reflecting the custom mode. if you switch from custom to default and back to custom it is ok.
i entered this into bz.
thanks and regards...
michael
Michael Merkel :lol:
saimo
Post by saimo »
Thank you!
