On my A1200 with Update 3 i had big GFX errors.But I found a solution
I had copy the ATIRadeon.chip file from Update2 into Update 3.
You find it inside Kickstart folder
Update3 ATI Radeon.Chip
- tommysammy
Re: Update3 ATI Radeon.Chip
What do you mean by Gfx errors? Here with my Bvision (16 bit screen only) the only thing I noticed is a "fusion" of the button's alpha channel in the Amidock drag bar, that tends to solve itself when I change the theme.
Could you give more details about the errors please?
I don't have such problem but I have 128mo on my Radeon.
PS: please update your signature with your current hardware configuration
- tommysammy
I had seen all in green red blue .The screen was very colorful
Could you confirm me that it works well with update 2 ATIRadeon.chip?
Is it possible to make a picture of the graphics glitches with a camera please?
- tommysammy
Yes ATIRadeom.chip from update 2 works welldavebraco wrote:Could you confirm me that it works well with update 2 ATIRadeon.chip?
I will make photos at this weekend
- tommysammy
Here are pictures
- Attachments
- SDC10724.JPG (96.79 KiB) Viewed 66295 times
- SDC10723.JPG (87.9 KiB) Viewed 66295 times
- SDC10722.JPG (74.12 KiB) Viewed 66295 times
- tommysammy
And more pictures
All is with AtiRadeon.Chip from Update3
- Attachments
- SDC10726.JPG (160.32 KiB) Viewed 66295 times
- SDC10727.JPG (190.31 KiB) Viewed 66295 times
- SDC10730.JPG (159.85 KiB) Viewed 66295 times
- LyleHaze
Wow, that is colorful!
Since update 3 came in, the boot image on my monitor is a bit off-center like yours. I don't have the noise at the top of the screen, and I haven't seen colors like that.
I just figured the off-center splash-screen was because I'm using a widescreen monitor. On mine, the beginning of the image does NOT show on the right side, just the
(cutoff) left side like yours.
I'm running a micro-AOne-C with a clean update 3, 256 Meg ram, and the builtin Radeon chip (of course)
My graphics modeID is 50091300, which is 1920X1080 ARGB32, 16 M colors.
Once I have booted into workbench, there are no problems at all.
I hope it helps,
LyleHaze
I hope it helps,
LyleHaze
