Since I installed FE on my X1000, I am no more able to use Workbench Contextual Menu to Copy/Paste files or drawers.
Each time, Paste action doesn't paste the file and sometimes, "ContextMenu Paste Task" abends (crashlog below) and very rarely I have a Requester from "ContextMenu Paste Process" with "??x?" stranges characters.
I noticed this problem since the clean install and even when I boot from the CD, Copy/Paste doesn't work.
Of course, when I drag'n drop a file between 2 volumes, the file is well copied. Duplicate works too.
No problem with 4.1.6 that I keep in another partition.
http://zzd10h.amiga-ng.org/FE/Crashlog_ ... -38-14.txt
Thank you by advance for your help
FE and Copy/Paste crash
Re: FE and Copy/Paste crash
Just grabbed the strange requester ;
I do not see this behaviour on my X1000 FE system.
My HDD uses sfs/02 blocksize 512b.
- MichaelMerkel
i also can not reproduce this here on my x1000.
maybe you can check with snoopy if smth strange is going on?
this is for every file? from/to every volume?
regards...
michael
regards...
michael
Yes, it's for all the files/drawers from/to all my partitions (and, as I said, even when I boot and use the DVD Workbench).
I tried with Snoopy to copy the file "Work:Bench9250.txt" to another sfs/02 partition named "Rien:"
In the Snoopy output, I don't find a reference to "Rien:" destination but again these strange characters. This time I doesn't show the requester.
Full snoopy log here :
http://zzd10h.amiga-ng.org/FE/FE_CopyPa ... Output.txt
Thank you
Guillaume
00242 : ContextMenus Paste Task : 0 = FindSegmentStackSize("<untracked>") [4uS]
00243 : ContextMenus Paste Task : o.k. = Lock("OS4_FE:Utilities/Commodities",SHARED) [53uS]
00244 : ContextMenus Paste Task : o.k. = Open("T:ContextMenus Clipboard1",OLD) = [0x18BEABD6] [41uS]
00245 : ContextMenus Paste Task : o.k. = Lock("Work:",SHARED) [22uS]
00246 : ContextMenus Paste Task : FAIL = Lock("ÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞ
00247 : ContextMenus Paste Task : o.k. = Lock("Work:",SHARED) [19uS]
00248 : ContextMenus Paste Task : FAIL = Lock("ÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞŸïÞ
00249 : ContextMenus Paste Task : o.k. = DupLock("Work:") [8uS]
00250 : ContextMenus Paste Task : FAIL = DupLock("<ZERO>") [1uS]
Thank you
Guillaume
Random thought, are your fonts all present, is your keymap set correctly?
I've seen this fault before. Years ago, it used to happen occasionally on all WB requesters. I raised a BZ for it and it was fixed (years ago). I have seen it again recently on my betasystems so perhaps it has crept back. I'll look up my old bug reports and see if I can find it.
BTW, the strange characters are in sets of four, and spell out "ABADCAFE" or "FEFECAFE" on the Sam 460. They are caused by a buffer over-run in the requester.
@ddni
yes all seems right. And it crashs too when booting the CD => Fonts in the CD should be OK, I presume.
@TonyW
Thank you very much to take a look at that.
And maybe a related problem again on my X1000.
1) Booting from the FE CD (or from my FE system)
2) RMB and select "New > New text file"
3) ContextMenu crashs !
4) If I ignore it, Notepad opens.
CrashLog from the boot from CD try :
http://zzd10h.amiga-ng.org/FE/Crashlog_ ... xtFile.txt
Hoping that a fix still exists
@TonyW
I found my old bug report and I have an idea what could be causing it. I've reverted to an older version of one component, but I'll have to run it for a week at least to make sure, then another week with the new one back in.
Meanwhile, I've reopened the old bug report (BZ #6064).
Re the "New/New Text file..." crash: It would seem that Notepad is trying to open a file on the CD and failing, bu that should not make it crash.
Can you describe more clearly what you did? Start from where you clicked the LMB *before* you clicked the RMB and selected "New". From which menu?
Thank you !
If you want to test it quickly, I am able to reproduce the bug everytime.
I could test it to please you, of course
