Whenever I press on of the buttons at the top in lister the whole bar disappear?
EDIT: It's a third party app and doesn't belong here? It comes with update 2 as an extra though. Not sure if I should report it here or not?
Sorting in Filer issue
- broadblues
Re: Sorting in Filer issue
You right that's it's a third party program, you should report the problem to the author, however, to save you time I can say that I allready did that and he is awarre of the issue.
Thank you, good to know.
