There is a Bug in Prefs/WBStartup 53.25 (06.10.2015):
Select a item from the Startup modules list, lets say SYS:Utilities/SGrab for example.
Click the Information button.
RAWBInfo will pop up showing the wrong icon information.
Bug in Prefs/WBStartup 53.25 (06.10.2014)
- MichaelMerkel
Re: Bug in Prefs/WBStartup 53.25 (06.10.2014)
there already is a brand new BZ entry for that.ZeroG wrote:There is a Bug in Prefs/WBStartup 53.25 (06.10.2015):
so this classifies it now as an officially known bug
regards...
michael
Is it loading the wrong icon or loading the correct icon but showing the wrong information??ZeroG wrote:There is a Bug in Prefs/WBStartup 53.25 (06.10.2015):
- tommysammy
I have a fixed version here, you have to wait for an updateZeroG wrote:There is a Bug in Prefs/WBStartup 53.25 (06.10.2015):
I don`t know when it appears
@xenic
It seems to show the deficon for .info files (project type)...
@tommysammy
@tommysammy
Yep confirmed, same problem here
just to add another issue on wbstartup prefsprogram... it shows progress icons at boot, even those not selected to start...you can even add a number of apps to run, select none to start and it will show the progressof them all... not the expected behavior... (of course... all of that provided you select "show progress window in the wbstartup prefs itself...).
Dragster
Dragster
- MichaelMerkel
the not-selected icons are shown as "inactive" icons AFAIK.Dragster wrote:just to add another issue on wbstartup prefsprogram... it shows progress icons at boot, even those not selected to start...you can even add a number of apps to run, select none to start and it will show the progressof them all... not the expected behavior... (of course... all of that provided you select "show progress window in the wbstartup prefs itself...).
so the behaiour is intended.
regards...
michael
How can you tell when the progress icons appear so fast? I haven't compared this behavior to OS 4.1u6, but I'm pretty sure it doesn't behave like that.. it only shows the icons of programs that actually get started...the not-selected icons are shown as "inactive" icons AFAIK.
regards...
michael
I'll find out that tonight and will report back.
Thank you,
D.
The deactivated icons are shown with a small red circle with a diagonal bar overlayed on them (looks a bit like a No parking sign).Dragster wrote:How can you tell when the progress icons appear so fast?the not-selected icons are shown as "inactive" icons AFAIK.
Not true, it has/had the same symbols overlayed.I haven't compared this behavior to OS 4.1u6, but I'm pretty sure it doesn't behave like that.. it only shows the icons of programs that actually get started...
Okay, go aheadI'll find out that tonight and will report back.
