Update 3 ScreenBlanker --> BoingBall freeze
samo79
Post by samo79 »
As title say since the installation of the update 3 i can't be able to "test" the BoingBall screensaver, if i try to click on "Use" in ScreenBlanker Prefs my Amiga will freeze instantanely.
My computer is:
Sam Flex 800
Radeon 9250
AmigaOS 4.1 Update 3 (of course)
Re: Update 3 ScreenBlanker --> BoingBall freeze
@samo79
I just tried test in the screensavar prefs on my SAM Flex 800 and the BoingBall screensaver works. Clicking use doesn't cause any problems. However, it was already an active module on my system. I tried moving it to inactive and selected use. When I reopened the screensaver prefs, test no longer works; it just goes to a black screen and returns. I moved the BoingBall module back to active and tried use and save but test no longer worked. I had to select save with BoingBall active and reboot to get it working again. I noticed that I still had the screen preferences for the BoingBall module set to 1024 16bit because i never updated it since getting a bigger monitor. I also notice that the BoingBall screensaver got ugly with Update3. The bouncing ball gets lines through it like the image movement isn't properly synchronized with the display. Something has apparently gone wrong with BoingBall when running Update3.
hotrod
Post by hotrod »
xenic wrote:@samo79
I tried to follow your example so I moved all blankers to be inactive, clicked use, reopened the window and the "Test" button wasn't clickable. I moved the boing blanker back, clicked use, reopened and CPU got stuck at 100% for a while, the little example was black (off course) but after some seconds it worked again. The blanker itself looks the same though. I got an A1 with a 9250.
Rigo
Post by Rigo »
BoingBall blanker works just fine here on my Update 3 machine, which is very similar to yours, a 733MHz Sam flex with 1GB and Radeon 9250.
I can only assume that there may be some errant files on your machine causing such problems. Whether these be libraries or configuration files, I have no idea, but perhaps trying a clean installation may fix your problems.
Simon
samo79
Post by samo79 »
Ok i did a clean install from scratch --> Fresh Update 1 then Update 2 and finally the Update 3
Now as you say all works as expected ( :)), no freeze at all using this screensaver, altrough many users experience hangs using it after installing the Update 3 on their "very-used" AmigaOS 4.1 Update 2 so i think some "small and hidden" problem still somewhere ... :?:
Rigo
Post by Rigo »
I don't doubt there is a clash somewhere, but finding it is the hard part. Unfortunately, what constitutes a "well used" system, is usually one that has been hacked to death.
At least it works for you now, and I'll wager it has fixed your other problems too.
Simon
samo79
Post by samo79 »
Yep, i would love to give you the exact step to reproduce but at some point i decide to erase all and restart from beginning.
Even MUI issues seems to be solved now (need more testing of course), there were some problem with MUI OWB fonts (on the GUI interface)
Aniway ... ;)
Hypex
Post by Hypex »
I can confirm there is a bug in the BlankerModule. Though I was unable which blanker it was. First I was downloading a file in OWB, Came back after five minutes system had frozen. I at first suspected OWB but grabbed a log which told otherwise. Had heard of it but now I had got a blanker crash!
I was also testing the new MUIOWB. Left it alone for a few minutes. Came back and another freeze had occured! :-o
So have a log. ;-) BTW what's with the 68K stack and instructions? Something has corrupted! :-)
Hidden Text - Click to Show :
Dump of context at 0x020991B0
Trap type: DSI exception
Machine State (raw): 0x0000F030
Machine State (verbose): [ExtInt on] [User] [FPU on] [IAT on] [DAT on]
Temporary stack trace:
#0: in module Kickstart/intuition.library.kmod+0x0008A5B8 (0x01A1EFF8)
#1: in module Kickstart/intuition.library.kmod+0x0001CDC4 (0x019B1804)
#2: in module Kickstart/intuition.library.kmod+0x00051D40 (0x019E6780)
#3: in module Kickstart/intuition.library.kmod+0x0001D4D0 (0x019B1F10)
#4: in module Kickstart/intuition.library.kmod+0x0001D634 (0x019B2074)
#5: in module Kickstart/intuition.library.kmod+0x00040EA4 (0x019D58E4)
#6: in module Kickstart/intuition.library.kmod+0x00040DF0 (0x019D5830)
#7: 0x7F2AC890
#8: 0x7F5675DC
#9: in module Kickstart/dos.library.kmod+0x00020A14 (0x01926A14)
#10: in module Kickstart/kernel+0x000416F0 (0x018416F0)
#11: in module Kickstart/kernel+0x00041770 (0x01841770)
#12: 0x00000000
Crashed process: BlankerModule (0x54EAB3B0)
DSI verbose error description: Access not found in hash or BAT (page fault)
Access was a load operation
0: 01A1EFF4 542CEC70 59032290 020A2AB4 6FF81DD8 00000000 00000000 021A3674
8: 3F5242EF 00000000 542CED38 54EAB3B0 48842084 41820014 00000000 577A4800
16: 02260000 00000000 02260000 00000000 5561EDC0 5A3050D8 00000000 7F567510
24: 5A305328 00000000 02270000 00000000 6FF814D0 6FF814D0 00000000 00000000
CR: 28842082 XER: 40004378 CTR: 0181C890 LR: 01A1EFF4
DSISR: 40000000 DAR: 00000084
FP0 : 0000000000000000 4082400000000000 4074A00000000000 0000000000000000
FP4 : 0000000000000000 4070FCCCC0000000 406DF999A0000000 41E0000000000000
FP8 : 4060000000000000 4032000000000000 3FF4000000000000 406FE00000000000
FP12: 3FF0000000000000 4081D00000000000 AC7BEFF7DAEAFCFA 1C8D57BCF7EEEEDA
FP16: BC0BBD75F7F77BF8 B0BFFFEEF11FFE7F FBFFFBCEFF7AEC7F 7D77BB9F9DB5FE39
FP20: BA1F8FAB5EE4EE63 FB1B5F2E35DDFC16 3F5F13FA5DFA7EDC EFB59FD0BE54FDB2
FP24: 783EDFEFFDC9EE9B BEDFBFAEFDE6EEFF A74FF7DFE5DFFDE6 B61F6FEECFFEFFF3
FP28: 7F7B6EADCFDFD679 FC5A3BAE277CCCBF BC5FEBBE5E61EEFB 9F1001C38FFFFEF9
FPSCR: 82004000
Dump of context at 0xEFAAD000
#7: 0x7F2AC890
#8: 0x7F5675DC
#12: 0x00000000
FP0 : FFF8000082004000 4082400000000000 4074A00000000000 0000000000000000
FPSCR: 82004000
Registers pointing to code:
r0 : module Kickstart/intuition.library.kmod at 0x01A1EFF4 (section 0 @ 0x8A5B8)
r2 : module OWB at 0x59032290 (section 4 @ 0x270)
r3 : module Kickstart/kernel at 0x020A2AB4 (section 1 @ 0x42AB8)
r7 : module Kickstart/kernel at 0x021A3674 (section 1 @ 0x143678)
r16: module Kickstart/bootimage at 0x02260000 (section 1 @ 0xAE04)
r18: module Kickstart/bootimage at 0x02260000 (section 1 @ 0xAE04)
r21: module Sys:Utilities/Blankers/BoingBall.blanker at 0x5A3050D8 (section 5 @ 0xB8)
r23: module LIBS:screenblanker.library at 0x7F567510 (section 5 @ 0x14F0)
r24: module Sys:Utilities/Blankers/BoingBall.blanker at 0x5A305328 (section 5 @ 0x308)
ip : module Kickstart/intuition.library.kmod at 0x01A1EFF8 (section 0 @ 0x8A5BC)
lr : module Kickstart/intuition.library.kmod at 0x01A1EFF4 (section 0 @ 0x8A5B8)
ctr: module Kickstart/kernel at 0x0181C890 (section 0 @ 0x1C894)
Stack Backtrace:
(0x542CEC70) module Kickstart/intuition.library.kmod at 0x01A1EFF8 (section 0 @ 0x8A5BC)
(0x542CEC90) module Kickstart/intuition.library.kmod at 0x019B1804 (section 0 @ 0x1CDC8)
(0x542CECB0) module Kickstart/intuition.library.kmod at 0x019E6780 (section 0 @ 0x51D44)
(0x542CED10) module Kickstart/intuition.library.kmod at 0x019B1F10 (section 0 @ 0x1D4D4)
(0x542CED30) module Kickstart/intuition.library.kmod at 0x019B2074 (section 0 @ 0x1D638)
(0x542CED90) module Kickstart/intuition.library.kmod at 0x019D58E4 (section 0 @ 0x40EA8)
(0x542CEDB0) module Kickstart/intuition.library.kmod at 0x019D5830 (section 0 @ 0x40DF4)
(0x542CEE20) module Sys:Utilities/Blankers/BoingBall.blanker at 0x7F2AC890 (section 4 @ 0x4870)
(0x542CEF70) module LIBS:screenblanker.library at 0x7F5675DC (section 5 @ 0x15BC)
(0x542CEF90) module Kickstart/dos.library.kmod at 0x01926A14 (section 0 @ 0x20A18)
(0x542CEFC0) module Kickstart/kernel at 0x018416F0 (section 0 @ 0x416F4)
(0x542CEFD0) module Kickstart/kernel at 0x01841770 (section 0 @ 0x41774)
(0x542CEFE0)
Disassembly of crash site:
01A1EFE8: 83A98408 lwz r29,-31736(r9)
01A1EFEC: 4BFCEC15 bl 0x19EDC00
01A1EFF0: 4BFCEBED bl 0x19EDBDC
01A1EFF4: 2F9F0000 cmpwi cr7,r31,0
>01A1EFF8: 801E0084 lwz r0,132(r30)
01A1EFFC: 93FE00D0 stw r31,208(r30)
01A1F000: 540006B0 rlwinm r0,r0,0,26,24
01A1F004: 901E0084 stw r0,132(r30)
01A1F008: 419E0078 beq- cr7,0x1A1F080
01A1F00C: 2F9F0001 cmpwi cr7,r31,1
Stack pointer (0x542CEC70) is inside bounds
Redzone is OK (4)
68k register dump
STCK: 0000AC4C 021B6866 0000AC4C 021B6866 0000AC4C 021B6866 0000AC4C 021B6866
STCK: 0182F110 0182C228 0182F110 0182C228 0182F110 0182C228 0182F110 0182C228
PC-8: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
PC *: 00003FAA AAAB3FC0 00004000 0000C000 00004454 C0004359 00003F19 999A3DCC
68k IP (r21) "Sys:Utilities/Blankers/BoingBall.blanker" Hunk 0005 Offset 000000CE (SegList: 0x16A7BB91)
Address of 68k IP r8 0x3F5242EF not found
----> 021B6866 - "Kickstart/kernel" Hunk 0001 Offset 00156862
Disassembly of 68k crash site:
5A3050D6: 0000 3FAA ori.b #0xaa,d0
5A3050DA: AAAB 3FC0 linea
5A3050DE: 0000 4000 ori.b #0,d0
5A3050E2: 0000 C000 ori.b #0,d0
5A3050E6: 0000 4454 ori.b #0x54,d0
5A3050EA: C000 and.b d0,d0
5A3050EC: 4359
5A3050EE: 0000 3F19 ori.b #0x19,d0
5A3050F2: 999A sub.l d4,(a2)+
5A3050F4: 3DCC CCCD move.w a4,(0xcd,pc,a4.l*4)
Page information:
Page not found
Last STCK bit repeates forever
Another:
#7: 0x7DE6B890
#8: 0x7F5875DC
#12: 0x00000000
Crashed process: BlankerModule (0x55D60240)
0: 01A1EFF4 5243FC70 00000000 020A2AB4 6FF81DD8 00000000 00000000 021A3674
8: 3F57CF2D 00000000 5243FD38 55D60240 48842084 00000000 00000000 583881E0
16: 02260000 00000000 02260000 00000000 55E04DC0 55D7C0D8 00000000 7F587510
24: 55D7C328 00000000 02270000 00000000 6FF814D0 6FF814D0 00000000 00000000
CR: 28842082 XER: 20000000 CTR: 0181C890 LR: 01A1EFF4
FP0 : 0000000000000000 0000000000000000 408A780000000000 0000000000000000
FP4 : 408A200000000000 40967F3340000000 408ADE6660000000 0000000000000000
FP8 : 408A200000000000 4060000000000000 40967F3340000000 408ADE6660000000
FP12: 4096800000000000 408B380000000000 AC5BEFF798E0F8DA 1C8947BCC7EE6E5A
FP16: AC0B3D75F75773F8 B1EFEFEEF119D67B 7BF7F3CEFF7AEC7F 7D77AB9F95B1FE39
FP20: BA5B0FAB5EE4AE43 FB1B5F2E355DFC16 3D4F03F81DFA5EDC 6BB59FD0B6547DB2
FP24: 683EDFEEFDC9EE9B BEDF1FAEDDE2EEFF A54FD7CDE4DFDDE6 B61F496ECFBEFED1
FP28: 3F7BAEADCFD2D679 7C5A1BAE0768CC9F B85FEBBE5E60EEBB FFFFFFFFFFFFFFFF
FPSCR: A3004100
Dump of context at 0xEFAADBA0
#7: 0x7DE6B890
#8: 0x7F5875DC
#12: 0x00000000
FP0 : FFF80000A3004100 0000000000000000 408A780000000000 0000000000000000
FPSCR: A3004100
r21: module Sys:Utilities/Blankers/BoingBall.blanker at 0x55D7C0D8 (section 5 @ 0xB8)
r23: module LIBS:screenblanker.library at 0x7F587510 (section 5 @ 0x14F0)
r24: module Sys:Utilities/Blankers/BoingBall.blanker at 0x55D7C328 (section 5 @ 0x308)
Stack Backtrace:
(0x5243FC70) module Kickstart/intuition.library.kmod at 0x01A1EFF8 (section 0 @ 0x8A5BC)
(0x5243FC90) module Kickstart/intuition.library.kmod at 0x019B1804 (section 0 @ 0x1CDC8)
(0x5243FCB0) module Kickstart/intuition.library.kmod at 0x019E6780 (section 0 @ 0x51D44)
(0x5243FD10) module Kickstart/intuition.library.kmod at 0x019B1F10 (section 0 @ 0x1D4D4)
(0x5243FD30) module Kickstart/intuition.library.kmod at 0x019B2074 (section 0 @ 0x1D638)
(0x5243FD90) module Kickstart/intuition.library.kmod at 0x019D58E4 (section 0 @ 0x40EA8)
(0x5243FDB0) module Kickstart/intuition.library.kmod at 0x019D5830 (section 0 @ 0x40DF4)
(0x5243FE20) module Sys:Utilities/Blankers/BoingBall.blanker at 0x7DE6B890 (section 4 @ 0x4870)
(0x5243FF70) module LIBS:screenblanker.library at 0x7F5875DC (section 5 @ 0x15BC)
(0x5243FF90) module Kickstart/dos.library.kmod at 0x01926A14 (section 0 @ 0x20A18)
(0x5243FFC0) module Kickstart/kernel at 0x018416F0 (section 0 @ 0x416F4)
(0x5243FFD0) module Kickstart/kernel at 0x01841770 (section 0 @ 0x41774)
(0x5243FFE0)
Stack pointer (0x5243FC70) is inside bounds
Redzone is OK (4)
68k register dump
68k IP (r21) "Sys:Utilities/Blankers/BoingBall.blanker" Hunk 0005 Offset 000000CE (SegList: 0x14DBEF89)
Address of 68k IP r8 0x3F57CF2D not found
55D7C0D6: 0000 3FAA ori.b #0xaa,d0
55D7C0DA: AAAB 3FC0 linea
55D7C0DE: 0000 4000 ori.b #0,d0
55D7C0E2: 0000 C000 ori.b #0,d0
55D7C0E6: 0000 4454 ori.b #0x54,d0
55D7C0EA: C000 and.b d0,d0
55D7C0EC: 4359
55D7C0EE: 0000 3F19 ori.b #0x19,d0
55D7C0F2: 999A sub.l d4,(a2)+
55D7C0F4: 3DCC CCCD move.w a4,(0xcd,pc,a4.l*4)
Page information:
Page not found
samo79
Post by samo79 »
Well isn't directly related, but the fonts problem with MUI OWB happen again even with a clean OS install, previously this problem never happen so it must be MUI OWB for sure, time to open a new ticket for MUI OWB on bugs.os4depot ;)
Hypex
Post by Hypex »
Heard of this. Did you run OWBB or the OWB launcher? I've only ran the atter. My install isn't fresh either. I wouldn't call it clean but it's not to dirty. :-)
