textclip.library
JosDuchIt
textclip.library
Post by JosDuchIt »
textclip.library/DisposeClipVector
textclip.library/DisposeClipVector textclip.library/DisposeClipVector
ReadClipVector -- read a string vector from the clipboard device
SYNOPSIS
ReadClipVector( vecptr, sizeptr )
LONG ReadClipVector( STRPTR *, ULONG *);
RESULT
A boolean success/failure indicator. In case of failure, the
size and the pointer will be nulled out for you.
I guess the result (LONG) is the vector's dimension? & not as described a boolean?
salass00
Re: textclip.library
Post by salass00 »
SYNOPSIS
RESULT
No, the result is just a boolean with non-zero for success and zero for failure. The size is written to the ULONG variable, the pointer of which you have provided as the second parameter to ReadClipVector().
JosDuchIt
Post by JosDuchIt »
I am stuck with using textclip.library to make a list from a multiline copy to clipboard fpr ListBrowser
(using clips:o as input file with LyleHaze's code , works ok, just a FORM line at the topMy wndow opens if nothing is in the clipboard too.
edit: after replacing the erroneous while check, the program freezes now after entering the loop with a muli line clip
and does not enter any more when the clip is empty
struct List *make_listbrowser_clip (BOOL yes )
STRPTR clipstring[TOTAL_LINES]; // =
STRPTR * clipstrings;
clipstrings = &clipstring[0];
ULONG* clipsizes;
ULONG clipsize[TOTAL_LINES];
clipsizes = &clipsize[0];
struct List *list=NULL;
LONG len, i = 0;
Printf("clip start %ld\n",i); ///seen
ReadClipVector(clipstrings, clipsizes);///ITextClip->
Printf("clip start %s\n",clipstring); /// seen with all the lines
if ((list = AllocVecTags (sizeof(struct List), AVT_ClearWithValue, 0, TAG_END)))
NewList (list);
while (clipstring[0] != '\0' ) ; /// no problem when nothing in, clipboard
Printf("clip loop %s\n",clipstring);
struct Node *node;
if (node = AllocListBrowserNode (1,LBNCA_Text,clipstring,TAG_END))
Printf("clip loop Allocdone %s\n",clipstring);
AddTail (list,node);
else
free_listbrowser_list (list);
return (NULL);
Printf("clip loop i %ld\n",i);
i++;
if (!(list->lh_Head->ln_Succ))
return (NULL);
return (list);
salass00
Post by salass00 »
Your loop doesn't work because in your arrays only the first element is initialised by ReadClipVector() so the contents of all others is undefined.
If I understand you correctly then a function like this should do what you want:
struct List *ClipToListBrowserList(void) {
    STRPTR clipstring;
    uint32 clipsize;
    struct List *list;
    STRPTR line, state;
    struct Node *node;
    if (!ReadClipVector(&clipstring, &clipsize))
        return NULL;
    list = AllocSysObject(ASOT_LIST, NULL);
    if (list == NULL) {
        DisposeClipVector(clipstring);
        return NULL;
    line = strtok_r(clipstring, "\n", &state);
    while (line != NULL) {
        node = AllocListBrowserNode(1,
            LBNCA_CopyText, TRUE,
            LBNCA_Text, line,
            TAG_END);
        if (node == NULL) {
            FreeListBrowserList(list);
            FreeSysObject(ASOT_LIST, list);
            return NULL;
        AddTail(list, node);
        line = strtok_r(NULL, "\n", &state);
    if (IsListEmpty(list)) {
        return NULL;
    return list;
Note that in this code I have changed the list so that it's allocated with AllocSysObject rather than AllocVecTags so this means that it has to be freed with FreeSysObject(ASOT_LIST, list) rather than FreeVec(list).
strtok_r() a standard clib function is used to split the string based on newline characters (you will need to include <string.h> for this).
JosDuchIt
Post by JosDuchIt »
@salass00
Thanks for the code.
I learned a number of things from it.
Do you agree however that using strtok_r() is a workaround that one wouldn't have to use?
ReadClipVector() delivers all the strings together(with their line feed )
Using strtok_r() eats empty lines too.
I can use LyleHaze's code (file to Listbrowser list) pointing a clips:0 which probably respects the empty lines,
salass00
Post by salass00 »
JosDuchIt wrote: Do you agree however that using strtok_r() is a workaround that one wouldn't have to use?
No, not really.
The current form is much more general and useful if you want to insert the text into a texteditor.gadget for example and if you need each line as a separate NUL-terminated string as you do it's not very hard to do the necessary conversion.
I rarely ever find a use for this function so I don't remember its quirks but if you need to keep the empty lines you should be able to use this replacement strtok_r() function:
char *my_strtok_r(char *s, const char *sep, char **state) {
    char *tok;
    char c;
    if (s == NULL && (s = *state) == NULL)
        return NULL;
    tok = s;
    while ((c = *s) != '\0' && strchr(sep, c) == NULL) s++;
    if (c != '\0')
        *s++ = '\0';
    else
        s = NULL;
    *state = s;
    return tok;
JosDuchIt
Post by JosDuchIt »
@salas00
OK & Thanks for my_strtok_r
