How do I change the SWAP priority so that the SWAP partition on a spare 1000rpm hdd is used first instead of ZorRAM?
ZorRAM works when I'm simply copying stuff to RAM: but it kinda chokes when I try to delete the things that I copied. Also it is not working properly under load (for example when using OWB)
I guess I need to add something to bootloader command since I could not find any relevant option inside the 4000T kicklayout file.
Changing SWAP priority
- danbeaver
Re: Changing SWAP priority
The system "knows" that Z3 RAM is faster than SWAP RAM and automatically uses it first. There is a way of changing the RAM priority ((Chip vs Fast) but I'm not sure it works the way you want. ZorRam is a slow down, but should not "Choke" on deletions; could you post some screen shots and be more explicit is exactly what is going on?
- DarrenHD
Unfortunately the swap partition priority is hard-coded into the kernel - there is no way to change it. You would have no choice but to remove your ZorRAM. You can read the Classic_FAQ on the pros and cons of swap partitions on hard disks vs. ZorRAM.ancalimon wrote:How do I change the SWAP priority so that the SWAP partition on a spare 1000rpm hdd is used first instead of ZorRAM?
Rotzloeffel
First: Z3 Ram is limited by the Busterchip to 10-13 MB per second...... Cybervision SCSI have a speed of 36 to 38 MB/sec on my A3000T with a SSD-HD!danbeaver wrote:The system "knows" that Z3 RAM is faster than SWAP RAM and automatically uses it first. There is a way of changing the RAM priority ((Chip vs Fast) but I'm not sure it works the way you want. ZorRam is a slow down, but should not "Choke" on deletions; could you post some screen shots and be more explicit is exactly what is going on?
Second: There is no usefull software available using SWAP! OWB is not able to use SWAP it is a Programmers issue! Not the fault of the OS!
so at the end: SWAP is actually useless IMHO
- Thomas Frieden
IMHO ?Rotzloeffel wrote: so at the end: SWAP is actually useless IMHOWe don´t need SWAP, we need RAM! There is no difference using SLOW SWAP or using SLOW RAM....IMHO
This isn't an issue of opinion, but of fact. You are leaving out the most important part in the equation, that of latency, which is HORRIBLE on chip ram, mainbaord ram, or any Z3 ram. When each and every access to memory requires 4 to 5 wait states, the memory becomes unusable.
For giggles, I once tried running code from mainboard memory. Was just outputting stuff to the console... Remember those old 300 baud acoustic couplers ? Those were faster than this...
So maybe the manual for AmigaOS 4.1 Classic should be updated to reflect this info?Thomas Frieden wrote:IMHO ?Rotzloeffel wrote: so at the end: SWAP is actually useless IMHOWe don´t need SWAP, we need RAM! There is no difference using SLOW SWAP or using SLOW RAM....IMHO
- danbeaver
Folks, if you check the threads in this forum on RAM access speed, this has all been discussed ad nauseam with all the numbers, including ways to free up more ram and crazy ideas like making a ram board for the CSPPC's PCI slot.
Rotzloeffel
Yes, you are rightThomas Frieden wrote: IMHO ?
Thanks Thomas! This is the FIRST time ever I got an explanation of the problem! I only heard it is slow, but I had no idea why and how slow it is... so thanks again.Thomas Frieden wrote: You are leaving out the most important part in the equation, that of latency, which is HORRIBLE on chip ram, mainbaord ram, or any Z3 ram. When each and every access to memory requires 4 to 5 wait states, the memory becomes unusable.
So do you think it would be a good idea to use OS4.1 on my A1200 instead of 4000T because of this memory limitation.
- danbeaver
The BlizzardPPC has other issues that outweigh the amount of available RAM between the A1200 and the A4000T. I never ran out of ram on my A4T unless I tried to by running huge memory hogs at the same time. If you think you really need that much ram, just buy an NG Amiga; they can access 2 GB at present with the even more as paged ram in the near future (info on this is also in the forums).
