about amistore
satiropan
about amistore
Post by satiropan »
the new frenzy in Amiga NG world is now Amistore, but...
I can't install it!.
once I download it, de-archive it and double click on its icon, an Elf Library window opens, stating: unknown/unsupported Reloc
if I reset and start again a guru window opens, with a DSI error, I tell it to forget DSI errors, the window closes and a new ELF window opens stating something else, I forgot to take note.
does enyone have the same problem?
any suggestion?
thanx
Satiropan
PPA1200 (Poor Portable Amiga 1200): BPPC-160MB,
BVision-CGX4, HD 10GB, slim DVD R/W, Asus VW161D
display, 3COM Lan PC card, OS4.1FE
AmigaOne G3-SE 600MHz, 1GB, Radeon 9200 128DDR,
CS4281 sound card, RTL8029, SiI3114, OS 4.1.6 & OS4.1FE
http://www.oldfab.webs.com
Hans
Re: about amistore
Post by Hans »
@satiropan
Is this with AmigaOS 4.1 with the latest updates installed? It sounds like either the archive got corrupted, or your elf.library is old.
It works fine for me.
Hans
satiropan
Re: about amistore
Post by satiropan »
Hans wrote:@satiropan
Hans
yes, it is 4.1.6 and I always did the updates found by Amiupate. What version is your elf.library? I'll check mine, BTW the archive should be ok, I had no problem un-archiving it
Satiropan
salass00
Re: about amistore
Post by salass00 »
@satiropan
If you have installed all the AmiUpdate updates you should have elf.library version 53.19 (27.3.2013).
To find out the elf.library version open a new shell and type in:
version elf.library full
Re: about amistore
@satiropan and anybody else who needs to know which version they were supposed to have of something:
Check out the useful list on http://update.amigaos.net/
(The list contains modules updated through AmiUpdate after update 6. Anything not on the list has not been updated since then.)
satiropan
Re: about amistore
Post by satiropan »
salass00 wrote:@satiropan
yes, the elf.library is the correct version, what else could I check?
Satiropan
ddni
Re: about amistore
Post by ddni »
Try running Snoopy before you start Amistore. It may give you an indication of where things are falling over.
