Maintenance Linux on a stick
Hi Linux gods,
i'd like to be able to do a "real" memory test on my installed 4GB (X1000) due to my system having problems and crashes of ramlib.support lately when going over 75% of the used 2 GB in AmigaOS (I'm trying to corner that problem to hardware-wise - memory sticks - or software-wise - should be addressed in the OS).
e.g. the "memtester" program from OS4Depot.net (yet overall not really trustworthy i was told), is smart enough to only address that much memory that is actually available...doing a fast test i tried to address 1.5GB - where 400 MB were in use by the OS - and it counted down to 853 MB, which it finally used - leaving me with 66% of used memory, while i don't know why it can't address the rest.
Not to mention that i got that dreaded ramlib.support crash on quitting memtester
Now, i do know nothing of Linux on Amiga and frankly, i don't want to read up all the tech talk either :-)
If someone could provide me a step to step guide on where to download and how to set up a minimalistic linux on an usb stick (it should not really do more than test the memory actually - i don't want it to be installed or tamper with my partitions) i'd be most grateful.
Thanks a lot
papaoskar
Re: Maintenance Linux on a stick
Post by papaoskar »
Why should it be a stick? Just use the DVD from Amigakit with Ubuntu12.04 !
It is definitly slow and the stick is'nt much faster.
papaoskar wrote:Why should it be a stick? Just use the DVD from Amigakit with Ubuntu12.04 !
Download link?
Download link?
I could add memtester to the SliTaz initrd.gz if you like.
Download link?
If you could add a guide on how to make it run, that would be marvellous, thank you
davebraco
Post by davebraco »
@ Raziel
It seems to be problem similar to this one :
http://forum.hyperion-entertainment.biz ... =33&t=1709
@davebraco
Thanks a lot for that hint, completely missed the thread :-)
So, here's hoping for a fix in FE :-)
Raziel wrote:@davebraco
Do you still need a SliTaz with the memtester?
Only if it won't mean extra work for you.
If you were doing it anyway then i'd be glad to test (wanted to run a memtest over the whole 4 GB anyway some time), but if you are going to spend time on it you could spend on other things, then please don't waste it :-)
Thank you very much for the offer, though
