CLICKTAB images
mritter0
CLICKTAB images
Post by mritter0 »
I would like to be able to put a different image (16x16) on the left side of a each tab. A good example is Google Chrome how it puts the site's logo on each tab.
You could not have both FlagImage and a custom image. Have to be changeable. Always on left, close image on right.
Is there a default close image or do I have to specify one? A simple x would suffice, like Google Chrome. Maybe switch to a capital X when click (and hold for visual) on it. Two Objects with LABEL_Text,"x", and LABEL_Text,"X", Center it vertically.
Re: CLICKTAB images
mritter0 wrote:I would like to be able to put a different image (16x16) on the left side of a each tab.
I suggested this many years ago.
No, no, no. The close gadget should always be on the left as per AmigaOS UI conventions.
I think you have to specify one. Not sure though. I use one of the AISS list images.
