YAM Crashlog: http://pastebin.com/V7FyJ4vq
IBrowse Crashlog: http://pastebin.com/axbKVJWF
AmigaOne XE with 1 gig RAM.
Update 3 IBrowse & YAM not working
Re: Update 3 IBrowse & YAM not working
danwood wrote:YAM Crashlog: http://pastebin.com/V7FyJ4vq
The same here..
uA1c FX + 256mb
Both IBrowse and YAM are 3rd party so I suggest you talk to the author(s) directly.
- DarrenHD
I will see if I can replicate this on my microA1 with Update 3 tonight.ssolie wrote:Both IBrowse and YAM are 3rd party so I suggest you talk to the author(s) directly.
Wouldn't be much help in the case of IBrowse, it hasn't been touched since around 2003 and we can't even get hold of a registration these days.ssolie wrote:Both IBrowse and YAM are 3rd party so I suggest you talk to the author(s) directly.
Seems this is more a MUI update issue breaking some apps.
Both continue to work fine on my system.danwood wrote:YAM Crashlog: http://pastebin.com/V7FyJ4vq
AmigaOne XE 1Ghz( Acube) with 1GB RAM.
- Stephen Robinson
Both working fine on my Peg 2, I'll try later (possibly tommorrow) on my µA1.
A few more problems, clicking MUI from within the MUI drawer is also a crash, Grim Reaper appears, running SabreMSN and clicking in the window is a system lockup.
Update:
I restored the MUI drawer from my Update 2 CD and everything is working now, IBrowse, Yam, MUI app, Sabremsn etc. so it's definitely a MUI issue with some configs. Hope we can get to the bottom of this.
I would suggest to remove third parties mui libs found mui:Libs/mui/ and check which ones are really needed by iBrowse and YAM. It's also important to be sure that up to date version of these libs are use.
